Results 1 to 13 of 13
    Sep 2009
    La Valle, WI
    Default What other Coolant colors work for F3's?
    Has anyone used prestone or other color coolant other than the orange color. Other than the brp brand I could only find GM's dexcool that's orange.
    2018 F3 Limited
    2018 F3 Limited , Oxford Blue
    Quote Originally Posted by JP58 View Post
    Are you sure you mean " Coolant " ..... Personally I wouldn't use " coolant ", I want an Anti-freeze ..... either way COLOR doesn't mater - other than don't MIX colors .... There are excellent " anti-freezes for less money than BRP's brand .... When I re-place mine I will switch to one of those .... and do a FLUSH to not MIX them together .... JMHO .. good luck .... Mike
    Sep 2009
    La Valle, WI
    In Wisconsin coolant/Antifreeze is in the same bottle. It does both.
    2018 F3 Limited
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Just did a coolant change out 11 days ago. Old coolant was Orange, so therefore used the GM Dexcool Orange also. Seems to be the only color, besides green, that we have in our area.
    And yes, our Coolant / Anti-freeze is one in the same here as well.
    2014 RTS Pearl White
    2014 RTS , Pearl White
    INDIANA, USA
    Default Coolant/Antifreeze
    Yes they are the same things. Just be sure to use the correct one as per the 'Spyder information '.
    'Orange Color' is usually the best for your Spyder.
    Based on the specifications by BRP-CANAM.
    They are so called brains of the Spyder Family.
    ENJOY YOUR LIFE WITH A SPYDER
    May 2014
    Benson, NY
    This is what I'm using, it checks all the boxes and it's orange.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Sep 2009
    La Valle, WI
    Thanks I will use Peak. Now on the F3L is the radiator hose the lowest hose to remove to drain. Can't see one on the engine. Anyone have a picture.
    2018 F3 Limited
    INDIANA, USA
    Default Drain Coolant
    ..For best and safe drain location remove the lowest hose from your radiator. As the drain plug is known to break off. ....
    My Dealer has told me this tip..
    Your Spyder and your money, been there and almost did the wrong thing. ......
    Feb 2022
    New Zealand
    Quote Originally Posted by Little Blue View Post
    Thanks for that info on the tip. I'm sure I will get to that soon as I'm setting up a Datum point on my new to me 17 F 3. Hard case your Dealer mentioned it.
    Quote Originally Posted by Bensonoid View Post
    I just checked Walmart which has 10+ containers .... however none have the same label as yours .... could you provide some Numbers etc. ...../ Thanks Mike
    May 2014
    Benson, NY
    Default Peak
    I'm going to go out on a limb and say the orange stuff Walmart has is the same as what I used. As you can see from the price my container is a couple years old. Here are some better pictures of the back label with all the specs. Looks like the only difference is that mine was concentrate not pre-diluted. These are all pics of the container I have.
    Sena 20s
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    https://www.owi.com/retail/brands/pe...lifetime-50-50
    PEAK GLOBAL is what I have been using in my Honda Valkyrie's since 2004 because they needed silicate free antifreeze.
    This is what I use in our Spyders also.
    T.P.
    The PEAK you show doesn't seem to be available now ..... It could be they do sell the same formula, but the Label has changed ..... Thanks for checking ..... Mike
