TPMS for the cost concious rider.
Hi. I would like to have your recommendations for a TPMS, Tire Pressure Monitoring System for those who are concerned about the cost of riding.
Thanks in Adance.
Eckhard
Spyder RT Ltd, 2011
I have the FOBO system, pick it up from Lamonster - love it
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is " Purl"
I know this is not exactly what you asked. But the most economical way would be not to buy one at all. Checking your tire pressures once a month is not that onerous a chore. IMHO
2018 F3 LIMITED
Once again, Billy beats me to the punch. I checked my Crapendas once a week and do the same with my Federals and Altmax. I have to add air less frequently with the car tires.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Nice novelty.....
Most understandable on semi's and transport vehicles. Many cars have them built in now to let you know when a tire is low. When they were introduced for the spyder there were issues and in the end many gave them up. I check tire pressure before any long ryde and it take a whole 3-5 min. Not saying you should not go that route but be prepared to be watching it as it all changes for temps altitude etc which you will waste time adjusting for as it will all change back down the road...jmo...
Amazon, solar charged, for cars but just leave one sensor off. Around 50 bucks. Have had for a while, works great. Nuff Said.
2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
If you have a Garmin GPS that supports the TPMS, then you can get the tire pressure monitors for a very reasonable price and have an integrated system with your GPS. I have this and I really like it. Very reliable.
Rob
I bought a Sykik Trike setup which came with 3 sensors. Their phone app is crapp, so I use another vendors, as is their after sales support.
That being said they work well.
I looked at the Garmin ones but it was cheaper to just buy a new bike if the pressure was low
Reason: More info
Rob
Did you change your valve stems to metal? I want to try the Garmin.. Thanks
Reason: Fixed quote display
SpyderLovers Sponsor
i bought a set a while ago,similar to fobo i think, and decided to shelve it for various reasons
i am now looking to fit a manually operated vi-air pump for my rear bag,as bike only has schrader valve access and its a pita to check(so i dont)
but i needed a dash mount air pressure gauge...i wasnt happy with things i found on line, so started looking at the TPMS again
fitted to the rear bag only,it was the answer.................so flushed with success,i fitted the other 3 sensors to the tyres
the problem i have is its beyond me to programme.....i cant set the base press(used for the alarm)and i cant change the units to psi,its stuck in BAR...i think thats why i shelved it previously....im ok with BAR,but would prefer Psi....does someone have a 3yr old he/she could lend me for a few minutes to set this thing up?
after powering the display up,i climbed on the bike,only to have the alarm going off at my every movement
so what i now do is press the display into the socket,read the data(albeit in BAR)then pull the display back out a little,effectively switching the unit off(mine dosent switch off auto either)then go ride....i dont need to monitor pressures as i go along,just at the start of the ride is ok for me
i think its a great idea,but only because i can incorporate the air bag
the supplier i bought from($AUD62) is no longer listed but this is the unit:
https://www.ebay.com.au/itm/External...8AAOSwCKRcwZBw
now i just need to fit the air pump and i can monitor my bag pressure
russ
pres ride
2014 RT-S
bike is WIP
bike has endured elect spike (was jump started incorrectly)
still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
I'm using these from Amazon... CAREUD Motorcycle TPMS Tire Pressure Monitoring System Wireless Digital Tire Pressure Gauge Tire Leakage Alarming System Waterproof 2 External Sensors Seller Mehart Cheater Hijack, Read Their Feedback
Sold by: Powtary Direct
Haven't had them on for very long but they seem to work well so far.
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars
Bending over or squatting down to check tire pressures can be quite hard for some of us old farts with bad knees and bad hearts. For me, squatting isn't too hard but getting back up is a bitch, and bending over with head below my waist then standing up again I almost pass out. While working on my Spyder, anything down low requires me to get down on my butt or back, then roll over onto my knees and get up slowly. IT IS AN ONEROUS CHORE for some of us.
Tag-Along trailer
Garmin 396 LM GPS
New Banshee AGM
