Tork number ?
Was wondering what the T number is for taking the panels off my 2015 F3s ? I know I'm suppose to have one but I don't. One of those dealer things.
You should get a set of them they are cheap most screws will be #30 Get a set with 25 to 32 you should be fine You can buy them any where 1/4 torx bit set.
My Spyder
probably either T27 or T30. You can buy a set of them at most hardware stores for under $10.00.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
IMG_0134[1].jpgIMG_0133[1].jpg If you use the T0RX25 on the front two bolts holding the side panels be sure to use wrist action and torque only as the brass nuts are easily pulled out of the composite flanges if you use a power driver or rachet.... also start the bolts back by hand to avoid crossthreading the brass nuts!!
Just a heads up - been there.
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
Most of them are T25 on the F3. There are a few T30's though.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
And there are a few T20 as well. Like the others said get yourself a set and be sure it has a 20, 25, 27 and 30. A set of metric sockets is a hood thing to have. An 8, 10 & 13 will cover most anything you might want to take apart.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
x2
My Spyder
