Results 1 to 12 of 12
    Aug 2019
    Tampbay Florida
    Default 2018 F3 Limited Speaker Volume
    Has anybody changed the speakers and if you did what kind and size and did you add a small amp. Did you run into any issues with the radio? The radio is way to low in sound for me on the highway. thanks for the advice.
    Apr 2016
    St. Charles IL
    Quote Originally Posted by psapman911 View Post
    I'm also interested!
    Bill W
    2019 F3 LTD
    Active Member Spyder Insyder's Avatar
    Sep 2018
    Payson, Arizona
    Do you have v20.8 firmware installed? Also try setting the ambient auto volume increase. I have a 2018 RT Limited with the 6 speaker audio system. After setting the auto volume increase, I get plenty of audio at 70 mph with the volume set at about 3/4.
    Active Member ChicagoSpyder's Avatar
    Chicago
    Quote Originally Posted by Spyder Insyder View Post
    How can you check to see what level of firmware you have installed?
    2018 F3 Limited , Black/Chrome
    Sep 2018
    Payson, Arizona
    Quote Originally Posted by ChicagoSpyder View Post
    On the right side of the dash, using the small joystick, go to settings, then select info. You will have a number there, that's the version you have.
    A few days ago " Billy Bovine " posted some info about this issue ….. He stated HOW to fix …… Mike
    Jul 2011
    Mitchell, Ontario, Canada
    I have a 2018 F3L and have no problem with audio volume. Using my android phone for audio. At highway speed with the volume at between 1/2 and 3/4. Also the the auto volume set to high.
    So we need more details. What is your audio source? If using your phone. What kind of phone, android or iphone? Are you using a device that plugs into the aux input?
    Jul 2011
    If you are using an android phone as your audio source. This may fix your issue. https://www.spyderlovers.com/forums/...-Android-phone
    Mar 2017
    Don't know if this has been mentioned, but Android detects something being plugged into the headphone jack and sets audio output to HALF. You need to go in and turn up the fone's volume. It will argue with you, but you can do it.
    Aug 2019
    Tampbay Florida
    using a iPhone 8
    Mar 2017
    using a iPhone 8
    Ahh! Information withheld until further investigation.
    Aug 2019
    Tampbay Florida
    I went for ride yesterday and made the recommended adjustments. Sound level ok but clarity was so-so. Might investigate putting better speakers and a small amp; will keep everybody posted thanks for the help- Mike
