Results 1 to 11 of 11
    Nov 2008
    las vegas, nv
    Default Battery not charging
    So I rode 1000 miles to Vegas and battery died on me overnight.
    Not completely dead but not strong enough to crank. (Progressives included roadside service came to rescue)
    Funny thing is it didn’t die the 3 nights after it was jump started the first time.
    When autozone tested the battery 2 days ago, cells were good but it said battery needed charging.
    You would think 1000 high speed miles should charge a good battery.
    Can output of stator be tested with typical volt/amp multi tester?
    6 states down 42 states to go
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Sure, just hook up your volt amp meter to the battery, test at rest ( not running), at idle and around 1500-1800 rpm. It will tell you what is going on. At rest should be >12v, at idle + or - 13 and >13 at higher rpm. Check your battery connections. Did you have any high draw items on during your run?
    Bob S
    Nov 2008
    las vegas, nv
    I have small amp and 2 sets of hid, nothing big and no extra lightings.
    Quote Originally Posted by GOZFST View Post
    Apr 2019
    Florida Swamp
    Check ground connections too.
    2019 F3-S , Black & Silver
    May 2017
    Mesa, Arid-Zone-A
    Symptoms of a dying battery.
    Semper Fi
    Idaho
    Quote Originally Posted by aka1004 View Post
    What Spyder and how old is the battery? A bad battery can show a full charge but still not have enough stored energy to start the bike.
    2014 Copper RTS
    Nov 2008
    las vegas, nv
    2015 RS and battery is 14 month old.
    It’s been sitting outside for last 2-3 month in heat as hot as 110, only getting ridden once a week for 2-80 miles.
    Default Battery....
    You said the battery is 14 months old so I wonder what brand it is and is it the oem battery. There are some battery testers that plug into the cigarette lighter and will give you condition and charging rates. The rectifier can also be a source of low or no charge but that would require testing the stator, rectifier seperately. I would venture to guess it will be the battery....
    ​2012 RS sm5
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    No battery tender and 2mile rides = toast!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Sep 2017
    Durham,Maine
    have a load test done, they don't lie!! Good luck
    2012 RTL , Pearl
    Nov 2008
    las vegas, nv
    RS is at dynojet for testing and they are putting it on a battery charger so we shall see if it holds that charge after I get it back. Thank you for all the inputs. I just hope it’s not the charging system.
