Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
  1. #26
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Hope the OP realizes we're only thinking of him and his passenger and not picking the installation apart.
  2. #27
    Dec 2015
    Oakley Utah
    Don't trust those bungee cords, especially the round ones. For absolute hold down security I suggest you use solid rope or chain tightened with turnbuckles. As others have said, a safety can made specifically for carrying fuel would be best.
    Suggestion...get a cheap battery box the right footprint...secure the battery box to the tongue...put gas can inside and strap it down with a battery tie-down strap.
    A couple pieces of angle aluminum screwed to the sides of the tongue makes a very strong platform for the battery box.
    2014 RTL Platinum
  3. #28
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Sounds good......isn't always possible. (This was a previous post of mine here.)
    Don't know how these get sorted in the posting list, as I didn't/don't see it directly under the posting I was responding to, so to clarify.....this was in response to the suggestion about "plan ahead and you don't have to worry about extra fuel".
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  4. #29
    Aug 2019
    Glendale, AZ
    I don't remember who's machine it was but recently when their back tire let loose it did a ton of damage to the back end of the bike. I can imagine that's a possibility w/ the gas can behind the wheel there. Use your own judgement though.
  5. #30
    Sep 2014
    tenino, wa
    thanks Idaho, already taken care of..
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  6. #31
    Sep 2014
    tenino, wa
    UtahPete, Modified already with a "plastic" box around it, but I am always looking for a better one. Battery boxes I've seen would be significantly oversized for what I need. This is only a 1 gal. container that fits in a 5x7x8hi space. Thinking about a surplus ammo or military box, if size is right.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  7. #32
    Dec 2015
    Oakley Utah
    Quote Originally Posted by teninospyder View Post
    They are significantly heavier...
    2014 RTL Platinum
  8. #33
    Sep 2014
    tenino, wa
    Battery boxes aren't tall enough from what I see. I need minimum 12"h ix10"L x6"W
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  9. #34
    Dec 2015
    Oakley Utah
    You could make your own out of aluminum. Doesn't need a lid
    2014 RTL Platinum
  10. #35
    Active Member ChicagoSpyder's Avatar
    Chicago
    Ah, no. Please don't carry any extra gas. If you were to be rear ended or were to rear end someone else, that container of gas would (could rupture) and splash forward and ignite. Need I say more?
    This is where we would carry extra fuel on sleds back in the late 90's thru the late 00's, the tank plumbed into the gas tank vent line thus sucking the Tour Buddy fuel first, the company that made them was called Tour Buddy.
    I suppose there was risk if you piled into a tree, but then again there was all kinds of risk sledding in no-mans land when the fuel stops were over 100 miles apart.
    2018 F3 Limited , Black/Chrome
  11. #36
    Bossier LoUiSiAna
    Couple using the lockable roropax system shared here while backIMG_4648.JPGIMG_0948.JPG
  12. #37
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    This is very similar to mine. It works well.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
  13. #38
    May 2013
    Apex, N.C.
    Quote Originally Posted by Jeriatric View Post
    For safety concerns this would cost a lot more initially but if the big 'IF' ever happened the chance of fire would diminish drastically.
    https://www.msrgear.com/msr-fuel-bottles
    Safety first.
    I have been looking in to one of those for my 2010 yamaha Vmax. That bike only has a 100 mile range. I have had no problems so far, I just fill up any time I come across a gas station once I have about 50 or more miles on a tank. But it would be nice to have that extra 20 oz, just in case.
  14. #39
    Oct 2013
    Wood Village OR
    After touring on our Spyders for the last 6 years and logging over 80K, We stopped packing fuel as we never used it for ourselves, only other riders. This year we did a Coast to Coast and back trip that lasted 11,000 miles taking all back roads. I never felt were going to run out of fuel even in the western states, we just make sure we fill up at the first station we see after we get to about 1/2 tank, when we had the 998s I carried fuel but never used it then but did get very low several times. The only issue we had carrying fuel was keeping it from being stolen twice. I never worried about crashing and fire,and I won’t say it would not happen,but almost does in every movie you see on TV The battery box is a very good way for secondary protection and security.721274FA-C9A7-45D0-84EB-1F0416347595.jpg
    2014 RTL , Black Currant
  15. #40
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    I willl get one of these, made for motorcycle carry
    https://www.revzilla.com/motorcycle-...orage-transfer
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
  16. #41
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Docster View Post
    They all need a mounting solution though.
    2014 RTL Platinum
  17. #42
    Northern Kalifornia
    If you really, really must carry extra gas, I'd go with the bladder from revzilla and place it in a commercial flight data recorder box and mount it to the outside of your trailer somewhere.
  18. #43
    Sep 2014
    tenino, wa
    Default Update on reserve gas can mounting for our 2014 RTL
    Following up on a prior post of mine showing the possible installation of a small bookshelf plastic "crate", on the tongue of our trailer to hold a reserve 1 gal. gas can.
    My "original" idea was to mount an army surplus ammo box on the tongue, but didn't have one close by.
    After completing the original install, I stopped at a few "Surplus" stores out here, and came up with a "perfect size" ammo can. Attached pics show the results. Recently finished a 700 mile trip with the gas can full and experienced "0" indication of any weeping of gas in the box.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  19. #44
    Faribault, MN
    Excellent idea! What else did you fit inside that can. Looks like a standard 50 cal ammo can with inside dimensions are 11''L x 5 1/2''W x 7''D.
    I know they also sell 30 cal and 40mm surplus ammo cans pretty regular, but the standard 50 cal (5.56 ball) is used for many, many extra containers.
    Now I think there's also a "Fat Fifty" or SAW surplus ammo can that's longer, wider and taller, inside dimensions are 11.9" x 6.75" x 8.2"
    By the way there is a lock kit that can be installed in the ammo can that a common key type padlock can be slipped through.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  20. #45
    Jan 2019
    Toowoomba Qld Australia
    Great work and really looks the part!
    Did you need to add any breather holes to clear any odour or vapour?
    2014 ST-S , Cognac
  21. #46
    Sep 2014
    tenino, wa
    Quote Originally Posted by glennm View Post
    Not yet. Even in high temps on our latest trip, when I opened the lid at "stops along the way", I saw NO indication that venting would help clear anything. I intend to keep an eye & nose on it though.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  22. #47
    Sep 2014
    tenino, wa
    Inside the can I also have a funnel, the original spout parts that came with the gas can (I added a "plain" top cap on the can to reduce overall height in the ammo box) , and some paper shop towels.
    The ammo box description can't be read under the black paint, but it measures on the outside, 12" long, 6.5" wide, and 8.375 hi.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
  23. #48
    Northern Kalifornia
    Much better, that looks fairly crash proof.
  24. #49
    Active Member Raknid's Avatar
    Central NJ
    Safety first.
    I use the MSR bottle on occasion. I have the 998 and range is not great. Generally not a concern out east until you get a bit north and in unfamiliar araas. Never had to actually use it...but a bit of insurance/piece of mind.
    2012 RT-SE5
