Results 1 to 23 of 23
Thread: Help
    Mar 2019
    Upstate SC
    Default Help
    Hi Fellow Rykerers,
    My trike has been intermittently making the whistling sound some have noted and now in left handed sweepers, on the throttle, it occasionally stutters as if starving for gas. Ideas??
    CENTAUR🤔
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Only thing I can think of is the VSS kicking in. What mode are you in? If you don't think you're going exceedingly fast or on the throttle too much then you may have a bad sensor.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Sep 2016
    clark county indiana
    super charger kicking in ? wondering if the airfilter canister is not closing correctly ( just a guess only ) or intake manifold boots are cracked ?
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by CENTAUR View Post
    Hi Fellow Rykerers,
    CENTAUR��
    My thoughts.
    If the fuel pump is whistling intermittently perhaps it's causing the gas starvation issue?
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    I was thinking about fuel starvation too, but I keep going back to "LEFT-handed sweepers". Is there anything that could account for that? Swinging pickup in the fuel tank maybe?
    Unless somehow the VSS is cutting power on left handers, and it might be a bad sensor as suggested by Poll.
    Jan 2018
    NH
    Quote Originally Posted by Zoot View Post
    That was on my mind also but I then I figured that if it was something in the fuel tank it would not be an immediate effect due to the fuel needing to go from the tank to the fuel injector. Possible a yaw sensor?
    Feb 2019
    East Texas
    Centaur, next time it does it, check your dash. It should show if the VSS is momentarily activating.
    Johnson, Vermont
    It's been my experience with the Ski Doo that when the fuel pump goes bad it doesn't work. The sled or in this case bike may start and idle but when try to go somewhere you can't build enough power, fuel pressure to make that happen. I think if the fuel pump were really the issue you wouldn't be moving at all?
    I have the interment noisy pump issue but other than being annoying it doesn't seem to affect the bike. I also haven't heard of any actual pump failures......just the annoying noise.
    Mar 2019
    Upstate SC
    Quote Originally Posted by poli View Post
    Eco mode.
    Mar 2019
    Upstate SC
    I have considered those possibilities.
    Mar 2019
    Upstate SC
    Quote Originally Posted by Markubis View Post
    Sensor was my first thought.
    Mar 2019
    Upstate SC
    I have looked for any kind of error notice. Nada.
    Mar 2019
    Upstate SC
    Thanks all for your thoughts. I'll be going to dealer and will post outcome. I just wish I could find one that is familiar with Rykers. One service manager told me, "You know more about Ryker than we do" and everywhere I check, 5 dealers, they are short handed and it takes weeks to get in.
    Jun 2019
    Florida
    Just out of curiosity, do you have a gas cap on it?
    Mar 2019
    Upstate SC
    Quote Originally Posted by MDLNB View Post
    No gas cap. Stock.
    Jun 2011
    Alamogordo, NM
    Centaur, you aparently stated that you were in eco mode, have you tried it in any other mode?
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Mar 2019
    Upstate SC
    Quote Originally Posted by old Timer View Post
    Yes. "Normal" same deal
    Mar 2019
    Upstate SC
    Cool Answer
    Took the RYKE to a dealer who took it for a ride and made it studder in both right and left turns. It's just the nanny kicking in. Just the nanny... doah!
    Nov 2018
    N.E. Ohio
    What was the whistling sound? cueman
    Johnson, Vermont
    You must be in ECO or ECO OFF mode?
    Mar 2019
    Upstate SC
    Quote Originally Posted by cueman View Post
    Do not know. It has disappeared.
    Mar 2019
    Upstate SC
    Quote Originally Posted by Rob Rodriguez View Post
    Yes. Did not realize I was cornering so hard. Guess I'll go to "SPORT" mode.
    Johnson, Vermont
    I've noticed now that we have cooler temperatures my fuel pump whine has stopped as well. 3000 miles and still going strong with no issues.
