Results 1 to 16 of 16
    Active Member jlc41's Avatar
    Jul 2018
    New Jersey
    Default Warning axle nut cotter pin missing
    I just want to FYI all, I have a 2018 F3LTD my drive belt was up against the flange. So I took a look see if I could adjust it. In so doing I discovered that the [B]cotter pin is missing. Further more the hole for it was not drilled through the shaft. I took it to the dealer and they aligned and drilled the shaft for the cotter pin. They could not believe that a flat nut with no lock washer would not have a cotter pin. You may want to check yours out I'd hate to think what could happen if that nut comes off at speed. Ride safe everyone.
    Joe
    Lamonster Bright Ryder,
    Lamonster Bright Tail Lighter,
    Lamonster H4 LED Headlights,
    Lamonster LED Fog Lights,
    Lamonster Fog Light Ring Combo,
    Rox Riser
    Lamonster Driver Back Rest,
    Lamonster Frame Mount Drink Holder.
    Lamonster 15" Freedom Shield Wind Shield
    ******* USA flag
    Freecom 2 head sets
    Mirror Wedgies by Squared Away
    Motorcycle Dave's Tachform phone cradle
    Spyderpops Turnsignal LEDs
    Spyder Sisters Shade
    Spyderpops LidLocs
    Spyderpops front fender LEDs by Show Chrome
    Motorcycle Dave's Gel seat insert
    2018 F3L , Blue
    SoFlo
    As I recall, the hole is drilled not through the threads, but through the stub end of the axle.
    In short, the cotter key does not prevent the nut from loosening, just prevents it from actually falling off. If you run the BRP trailer hitch, the cotter key is removed, the hit is installed, and the long bolt for the hitch safties the axle with long bolt having a cotter key.
    Default Interesting....🤔
    Good catch... must have been a batch of undrilled axle bolts but does make you wonder why it was not caught in assembly.... Worth a look F3 owners that have not been in that area as yet....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2012
    North Las Vegas, NV
    I just checked my 2016 F3L and it has a cotter pin.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2018
    New Jersey
    PMK, you are correct the hole is drilled through the stub end precisely to keep the nut from coming completely off.
    Rox Riser
    ******* USA flag
    Freecom 2 head sets
    Spyderpops LidLocs
    2018 F3L , Blue
    SoFlo
    Quote Originally Posted by jlc41 View Post
    My thought was BRP did not believe it should require removing the cotter key to tension the belt. Regardless, I did away with the cotter key and went to a reusable safety pin. No more bending the cotter key to remove when needed, or grabbing a new one. Simply unclip as needed, and reclip after install.
    Sep 2018
    greensburg,pa
    But if the nut becomes loose the belt would walk off the pulley. From what I've already read no 2018's have a cotter pin anymore mine included. Could anyone show this on a repair manual if its required?
    No being an ass, but I would ASSUME BRP would of addressed this already if it was a safety issue.
    Update: I found this remembering I read it in this forum.
    https://www.spyderlovers.com/forums/...=1#post1440860
    2018 RT-L , Blue
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    my 2014 RT had a castellated nut, but no cotter pin.
    " 2017 RT has " " " " " " "
    never really missed them. Of course I don't dink around with my axle very much.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Sep 2018
    greensburg,pa
    I did send BRP a email about this with a picture of my axle and may be we can get an answer........
    2018 RT-L , Blue
    Jul 2018
    New Jersey
    To me it's just common sense to have the cotter pin. Why, because there is no lock washer. Why tempt the hand of faith. I guess having worked around cars and heavy machinery it's just prudent to have it.
    The starter hole is already there, my dealer drilled through and installed the cotter pin. They all commented that it should have been there.
    Joe
    Rox Riser
    ******* USA flag
    Freecom 2 head sets
    Spyderpops LidLocs
    2018 F3L , Blue
    USA
    My 2018 RTL had one side of the axle drilled, no split pin. I drilled the other side and installed the split pin when I replaced the rear tire. Overabundance of caution I reckon. Thankful they at least gave me a pilot hole on one side.
    h0gr1der
    Mar 2018
    Ontario ,way up north
    2018 RTL no cotter pin .
    2018 RTL , dark blue
    Active Member BigBlock's Avatar
    Jul 2018
    British Columbia, Canada
    No cotter pin on my 2018 RTL either.
    2018 RT Limited , Champagne
    Sep 2018
    Sneedville, TN
    No cotter pin on my 2018 RTL. I asked dealer about this and Spyder tech confirmed that its correct for my bike. No pin used.
    2018 Spyder RT Limited
    Asphalt Gray
    Can Am Passenger Armrests
    Can Am Comfort Seat
    Spyder Accessories Floating Footpegs
    Utopia Driver Backrest
    Bajaron Sway Bar
    Sena 20s Bluetooth
    Lidlocks Helmet Holders
    F4 Tall and Wide Tinted Windshield
    Fobo Tire Monitor
    Lamonster Spyderdock Cell Phone Holder
    Sheepskin Seat Cover
    Drink2Go Cup Holders
    Magic Mirror
    Can Am Trailer Hitch
    Missing Belt Guard
    Wish List - LED Headlights and Fog lights
    Houston
    The pin has been removed as part of the hitch installation for years. Guess BRP decided it was no longer needed at all.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2018
    greensburg,pa
    This is what they (BRP) replied with.
    thank you for taking the time to contact BRP Customer Services.
    As you may know, our dealers are more than just sales people; they're the best positioned people to help you with most of your requests, as they are not only technically knowledgeable, but have a lot of information on hand at the dealership. I would recommend that you to get to know them better so they can help make your riding experiences unforgettable.
    Please feel free to use our dealer locator option on our website www.brp.com. I have copied the direct link to this option below for your convenience:
    https://can-am.brp.com/on-road/dealer-locator.html
    Please feel free to contact us anytime.
    Best Regards,
    Aniko Zsigmond
    Customer Service Representative
    BRP Support Desk Services
    I'm okay with out the pin - for what ever reason its not part of the axle anymore and since my spyder has been to a dealership several times Im not losing sleep over it. I wonder if its a Prevailing torque nut? I noticed how stiff it is on the axle even when the adjuster were lose.
    2018 RT-L , Blue
