Results 1 to 12 of 12
    Apr 2019
    Tennessee
    Default Squealing Brakes
    My brakes now squeal at low speed when I get close to a stop. Does anyone have this issue? How do you get rid of it. Its annoying.
    western Colorado
    Try going up to 40+ mph then hard slow down but don't completely stop a few times.
    Apr 2019
    Kansas
    More than likely some sort of debris on the pad or rotor. Inspect and clean with some soap and water.
    Northern Kalifornia
    Power wash.
    May 2018
    millsboro,delaware
    Do not powerwash,you could wash off hardware lubricant or push water past seals.There is no easy fix but if you can take the pads off then look at pads and look for any sort of debris lodged in the pad material.Sometimes pads just squeal and all you can do is change brands or just replace.My RT rear pads squeal when they get real hot like when going down a long series of mountain switchbacks
    : 2017 RTL ORBITAL BLUE
    Apr 2019
    Kansas
    Yep, don't power wash
    Sep 2016
    Chillicothe, Oh.
    If you take the pads off to do a closer inspection apply some brake grease to the rear of the pads where they contact the caliper pistons. It is often vibrations that raise the noise and this grease will help dampen those vibes. You can get small packets of this stuff at any auto parts store and many stores will include a few packets when you buy new pads. I often relate the pads vibrating to the cricket. Listen to the noise they can make simply by rubbing their legs together. Usually under the refrigerator at 2 am. It doesn't take much vibration to make a brake screech LOUDLY.
    2015 RT , Black
    Dec 2018
    NY
    Mine stopped after riding through a rainstorm.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    +1 for pad lube, especially considering it's at light load slowing to a stop.
    Jun 2019
    Florida
    Humidity can cause oxidation(fine layer of rust) on the disks and cause a squeal when you apply the brakes. I have an old ford that does that and I usually just increase speed and then hit the brake to scrape the oxidation off real fast. Then the car is fine for the rest of my travels. Just a thought.
    Dec 2013
    with that, and I've noticed that the brakes on my RT only ever squeal on the gentle, tentative applications! No squeal ever on the firm applications, but (for example) if I'm coasting to a stop & gently feather the brakes as I roll in, you'd think I'd run over a bloody great mob of baby rabbits!!
    So I now try to use firm or positive brake applications all the time, & especially for the first few applications on starting a ryde after leaving the Spyder standing for a few days - no more squealing!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2012
    Spring City,Utah
    NAPA and Prestone both make a good anti squeal. Don't leave home without it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
