Results 1 to 14 of 14
    Jul 2019
    Iowa City, Iowa
    Default Get the rear axel nut loose
    I wish I had a good air wrench. But since I don't, I tried to use my own power to loosen the rear axel nut on the right side of the bike.
    I need to take some of the tension off the drive belt. Im getting 200 pounds on my Gates meter that I just bought in order to check it.
    Also my drive belt is only about 10-12 thousands away from the shoulder on the rear sprocket.
    But I couldn't break it loose. Anybody have any ideas other than buying a new air wrench?
    Mar 2013
    Marion, Arkansas
    Not sure what you are using to try to break the axle nut loose but you may need to purchase a wrench that is long enough to get you some leverage or use a breaker bar and socket to get it loose.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jul 2019
    Iowa City, Iowa
    I've got the breaker bar and socket.
    I'm going out to get a 2-3 foot piece of pipe in order to get even more leverage.
    Thanks much, Jim
    Quote Originally Posted by JimSter View Post
    Thanks much, Jim
    I was going to suggest this - however you figured it …… good for you ….. Mike
    Mar 2017
    Here are the parts I bought and made. Advantage is getting a torque wrench for 180 pounds in the mix. Minimum for the belt is 1mm or 0.04"
    >36mm socket which works with the oil filter too<
    >1/2 inch torque wrench / breaker bar<
    >36mm box/open end wrench< cut in half for use
    Florida Swamp
    Or maybe a 36mm hammer wrench...............
    2019 F3-S , Black & Silver
    Harrington, Australia
    What year do you have, Jim? They really tightened those nuts up from 2013 on. I needed to get a 3/4” drive and a 2.5’ breaker bar to get my 2016 Limited loose. They jumped from roughly 90 pounds to roughly 160 pounds from 2013.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Quote Originally Posted by Rattlebars View Post
    Ok, I give up . . . I've got a 36mm box/open-end wrench but what's the reason you cut it in half ? (I've also got a 3/4" drive torque wrench with 36mm socket in my tool chest - breaker bar too). Obviously I haven't had the occasion to loosen my rear axle yet so this is useful information.
    2019 F3 Limited , Oxford Blue
    Florida Swamp
    Quote Originally Posted by LifeLongRider View Post
    With a cut wrench you can flatten the end of a water pipe down some and use it as a cheater. If you don't saw the wrench in half you can only double wrench for a cheater, which is a good way to need some new skin on your knuckles.
    If you have the 3/4 inch breaker bar you shouldn't need a cut off wrench. You can just put the cheater pipe on the breaker bar if you need more umph.
    Aug 2018
    Florida
    Quote Originally Posted by Gwolf View Post
    Thanks, that makes perfect sense. If I remember correctly, my 3/4" breaker bar is 24" I believe which should be plenty long enough. My 3/4" drive torque wrench is 34" long.
    Florida Swamp
    One thing about that......... you may want to carry a cut off wrench with you. You can always find a piece of pipe somewhere (hardware store, plumbing supply, Lowe's, etc.) to use as a cheater. It would be a lot easier to store a sawed wrench on the bike than to try to find a place to carry a 2 foot breaker bar.
    Jan 2019
    Hunter Valley NSW Australia
    I took mine off two days ago, used a socket on a 24" breaker bar and a 4 ft long piece of 3/4" water pipe.
    Ditto for re-torquing it
    2017 RTL , White
    Durham,Maine
    I think the whole deal is that you can easily put it in the tool bag and travel with it! If you have room for the breaker bar and socket even better on your body!!
    2012 RTL , Pearl
    Mar 2017
    It's pretty long so it's easier to store on the bike in two pieces. You need to hold one side of the axle while turning the other side nut. The open end will go over the right side nut while still keeping the cotter key installed for belt tensioning. If you have bags installed, the wrenches fit nicely while a socket is a b**ch. If you watch the video, it will be clear as to the advantage of cutting.
