Results 1 to 13 of 13
Thread: Spyder Touring
    Oct 2016
    Sebring, FL
    Default Spyder Touring
    As I understand, there are now only two RTs, the RT and the RT Ltd. No more RT SE6, RTS, or RT manual, whatever that designation was. Too much confusion here. Not looking at the F3 Touring, fine looking machine, but bars are too much reach for me for comfort.
    Sep 2014
    USA
    Yes they have the SE6 is semi auto trans shifting
    Oct 2016
    Sebring, FL
    Yes, I see it now, thanks. Much like the RT Ltd, only dark and maybe missing an accessory, did not dig that deep.
    There are RT, RT-S, and RT LTD.
    The RT is a base line RT. The RT-S has more bells and whistles. Cruise, Radio, Auto air suspension, driving lights and plastic chrome decorations. The LTD comes with some actual chrome, pieces and a garman navigation system. SE6 refers to Semi Auto 6 speed transmission. Not sure if they still make the SM 6 (manual transmission).
    I did not look up from the web site. I believe most of the above is correct. You can correct any errors.
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    On the F3 you have 3 or 4 bars to choose from. I have the short reach bars. These are just right for me.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Dec 2015
    Oakley Utah
    Are you asking a question? Not sure the point of your thread
    2014 RTL Platinum
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    RT Limited no longer comes with the Garmin Navigation since the new dash blue tooth connects to your cell phone, that is now your navigation. You can still get the Garmin but it is a healthy price tag, and they are still using the old version Zumo 590 and not the 595
    2022 RT Limited , Silver w/ Black and Purple accents
    Jul 2014
    Mint Hill, NC
    For MY 2019 there is the Spyder RT and the Spyder RT Limited. They both come with the SE, semiautomatic, transmission. The Spyder RT comes in only one color, Pearl White, while the RT-Limited comes in eight different color combinations, has some real chrome and some other options.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2018
    Vancouver, WA
    Just an FYI, the Spyder F3-S is the only model that has the option of the SE6 or SM5. The F3-S Special Series only comes with an SE6. All Spyder RT's have the SE6 as the only transmission. This applies to all 2019 Spyders.
    Oct 2016
    Sebring, FL
    Utah, just trying to clarify, got some good answers here, that was the point. For instance, I did not know there were three different bars for the F3, and some other enlightening responses. Sorry if I was not specific enough, I thought it was a reasonable post, maybe not.
    Sep 2014
    USA
    Bill it all depends on what year you are looking at getting I guess. But the Rt can have the Triaxis bars added or find a good used on all loaded up and saves you a ton of cash.
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    https://can-am.brp.com/on-road/spyder/touring.html
    You can read the differnt options on a rt and rt Limited just click on the left of screen
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Jun 2010
    Las Vegas
    If you’re thinking about an RT you should consider the Tri Axis handlebars. They are great but expensive, if you can negotiate them into your purchase you might save money, especially if the Spyder is still in a crate.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
