Results 1 to 3 of 3
    Mar 2012
    north tonawanda ny
    Default suspension having problems to adjust?
    2013 rt 20000 miles...for 75% of the time I keep getting a 3 second sound like the suspension adjusting..then 2 seconds of silence then keep repeating.. it is also quite loud.. will go off when emergency brake is put on.. no warning lights.. spyder riding fine.. only thing I can think of when it started, I hit one of Niagara falls finest pot hole..besides that not a clue... any thoughts..Jim
    Faribault, MN
    Jim, it's likely you have an airbag leak, or airbag checkvalve failure. There are many, many threads on here about troubleshooting, repairing, or replacing your rear airbag or components.
    Start with the How To check for leaks in the airbag thread
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Have always been curious if rear shock failure and level of inflation intersected?
    If you don't mind my asking.
    What was your normal level of inflation?
