Brakes
I replace my brake linings on a 2015 RT and can not get them to stop squeaking. When I replaced them I completely removed the old ones and cleaned everything with brake cleaner. I have even removed them the second time and recleaned them. Still squeaking.
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
A light coating of copperslip on the back of the pads usually does the trick.. never put them in dry as they will squeal.
If you bought your new pads from BajaRon, in the directions he sends with them are suggestions on how to deal with the squealing. Briefly you can bevel the edges, use a hacksaw blade or file to cut a groove down the center vertically and there is a disk brake anti squeal lube you can put on the back of the pads. I use NAPA Sil Glide, but there others that work good.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Thanks for the fast reply. I will try this.
Asphalt Grey
Sena SMH-10
Garmin's GPS
