Rough Idle, Check Engine then Limp Mode after Storage
Took the RT out of storage yesterday. Installed the battery, it started quickly. Bit of a rough idle at first but it smoothed out quickly and seemed fine.
After it warmed up a bit the idle became very rough, then the check engine light came on and soon Limp Home mode and it would not idle at all without help.
Shut it off, waited 15 minutes bit but the same result.
Took it out for a ride hoping it would clear but after a couple of minutes Limp Mode again.
Disconnected the battery for an hour then tried it again but same result...rough idle, check engine then Limp Mode.
Read the codes: P2279 and P0106 which both hint at air leaks and manifold pressure issues.
The RT ran flawlessly last season (8000Km, 5000mi). Rode right into December and it was running fine the day it went into storage. Changed the oil and ran it for a couple of hours then. Removed the battery and kept it charged over the winter.
Thoughts or suggestions.
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
Did you put stabilizer in the fuel? Last fall I had untreated hi-test 93 octane fuel go bad in my BMW 1150RT in less than 2 months. Machine would not start in my case at all, fresh fuel and she ran like a top as usual.
Could be bad gas but that doesn't normally cause Limp Mode. This may sound funny but I would check the vacuum hoses and wiring. It's a long shot but possible mice may have decided to winter over in your Spyder and made a meal out of the hoses and wiring. I'd be making an appointment at the shop though.
I agree about the fuel stabilizer and possible bad gas, as well as the possibility of water in the fuel from condensation if the tank wasn't fully topped off, or from absorbtion due to ethanol fuels. Your fault codes seem to point in another direction, though.
P0106 = Manifold Absolute Pressure circuit range/performance...indicating a problem with the MAP sensor not reading as expected
P2279 = Intake Air System Leak...normally indicating a cracked manifold or a gasket leak
I would look at a couple of possibilities. First would be checking the air intake and airbox for a mouse nest. A blocked intake could cause both these faults. Second, I would look carfully for cracked or chewed vacuum hoses. Both these problems indicate improper intake pressure/vacuum...and mice are typical offenders wen it happens over the winter, with the ravages of temperature change on previously heated rubber hoses running close behind. I'd also add some Marine Stabil or Seafoam and some fresh gas. It can't hurt.
Several good suggestions here, could be any one of them. I have been a pretty fair backyard mechanic most of my life and was a field service engineer for over 10 years. One thing I learned, sometimes the hard way....
Check the easy simple things first.
Going to check the easy things first
Thanks for the suggestions.
The gas was stabilized before we put it away. So we will pull off the panels and check for obstructions, leaks and cracked hoses.
If that doesn't reveal anything its off to the dealer next week. If you are going to have these type of problems its a good thing they happen at the beginning of our riding season.
Thanks again. Will report back with the solution.
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
Vacuum lines
My friend had a problem with his RT recently it would idle rough, check engine light would come, would not downshift automatically. The vacuum lines were broken due to heat exposure, yours probably as Scotty said, could be a mouse has chewed into to them while yours was in storage, a possibility. After my friends vacuum lines were replaced it ran fine. If your spyder is SE5 shift, the paddle shifter works off of vacuum. Try this, ride your spyder and see if it downshifts automatically when coming to a stop, if it doesn't and stalls out it will probably be the vacuum lines. Just trying to help you troubleshoot your problems, I hope you get this figured out soon.
Good Luck!!
Any chance this could be a classic "frozen-block" problem due to low coolant/antifreeze? I certainly hope not for this person's sake.
Just wondering how much it would take to freeze these motors to cause damage like a cracked-block and etc.
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
Even with stabilized fuel, moisture can collect in the gas tank from condensation if the tank is not full. Ethanol can also cause phase separation if there is insufficient stabilizer or excessive moisture. Don't automatically discount the possibility just because you stabilized before storage. Never assume anything!
SOLVED ==>Rough Idle, Check Engine then Limp Mode after Storage
Well it was a cracked vacuum hose (see pics below). No critters, nests, no "chewing" and no bad fuel. The P2279 and P0106 codes were correct.
On the left side under the acoustic panel there are two small vacuum hoses (3.5" long) that run to the Manifold Air Pressure Sensor (M.A.P.S.). The one that is on the front of the M.A.P.S. adapter was cracked right through at its 90 degree bend. The one that is on the rear of the adapter was cracked too but not right through.
I replaced the hoses with 4" pieces of vacuum hose and the RT ran better than it did in the fall. After idling rough at first start it settled down to a smooth 1400 RPM. No check engine and no LIMP Mode, Yea...my wife is happy again. A test ride just confirmed this.
I can't see how this will not be a perpetual problem. The forward hose is quite near the forward cylinder. It will dry out from the heat, crack and probably split again. We're going to carry two 4" pieces of vacuum hose in the ever growing spares kit. Now that I know where to look its a 30 minute job to replace them (if the mirror cooperates!!)
Many thanks to everyone for their tips and suggestions.
John
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
Glad to hear you found the problem. Thanks for sharing. That hose looks pretty bad for being less than 2 years old, perhaps defective?
Thanks for reporting the cure. Good idea on the vacuum hoses. I think I'll add some to the spares kit.
Good news
Glad to hear you got the problem solved. My earlier comment I made on your post of my friend's RT is also a 2011. His vacuum hoses did split and break due to heat.
Glad you got it going w/o too much problem.
John
Reinforced hose are better replacement just my opinion
Just a follow up
Marilyn called the Dealer (Uxbridge MotorSports) today and explained the situation They are ordering the two hoses under Warranty and letting us install them.
The BRP part number is: 420960115 Hose, Sensor and is priced at $11.99 ea.
Interesting in that I bought 2 ft. of the correct Inside Diameter Vacuum hose from NAPA for 97 cents (including tax). That's enough for 6 of my 4 inch spares.
John
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
I just picked up my buddy's 2010 RT and I think it has a broken vacuum hose too... I'm just taking it to the dealer and dropping it off and picking mine up.
John
John
Can you tell us the correct diameter? Or NAPA part number?
RT and Gold Wing States & Provinces
NAPA Part Number: H458 Wiper & Vacuum Hose
0.43 per foot (CDN)
John
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
0.43 per foot (CDN)
John
Thanks. According to the NAPA website, this hose is for fittings with a 0.125" (1/8") diameter. The hose itself has an inner diameter just slightly less -- 0.109375" (7/64"). Just in case a NAPA store isn't handy.
Following up on my own post, I just explored the NAPA site further and found a silicone vacuum hose with the same dimensions -- NAPA Number H466. The silicone hose is for "harsh environments" and has a higher temperature rating than the standard black "rubber" (EPDM) hose. The silicone hose has a minimum bend radius of 1". I don't know if the original hose is bent sharper than that. The EPDM hose doesn't have a specified minimum bend radius, just labeled as "kink resistant". If temperature is really the culprit here, and you can route it so the silicone hose won't kink, silicone might be worth a try. ??
Just curious. I had the same problem with the vacuum lines. How many have the SpyderPops radiator block off plate installed? Could the contained heat from the plate be the cause of the cracked vacuum lines?
Cracked Vacum Hose
John
If search the forum here you will find that cracked vacuum lines to the MAP sensor are a somewhat common failure.
Because of the heat under the plastic, it has been suggested that when this occurs to replace the broken line(s) with high temperature resistant silicone vacuum lines. to prevent future failure of the lines. I plan to buy and carry two spares for my RT-S my self.
Anyway.... I am really glad to hear you found the problem.
It should run excellent for you now.
- Rd_runner
- Rd_runner
Ahhhhaaaa....I see as I finished reading the remaining posts in this thread others have already identified the better silicone vacuum line as a solution.....
Rd_runner
Tags for this Thread
