Results 1 to 5 of 5
    Active Member Trapdoor's Avatar
    Jun 2016
    Killeen, Texas
    Default M10 Torque Spec.?
    Please, I need to know what the torque specification is for the Allen bolts that secure the rear fender support. I have a 2017 F3S-SE that I took the rear fender apart for a wash, wax and paint job. The marking on the bolts is "A2-70 THE". An internet search produced 37 ft-lbs (dry) / 28 ft-lbs (wet). I'm not sure if the result meets Can-Am specs. Thanks.
    Sep 2009
    La Valle, WI
    Just snug it up. Torque does not really matter on a fender.
    2018 F3 Limited , Oxford Blue
    Apr 2019
    Florida Swamp
    To get the correct torque values, you must consider the grade and material of the fasteners. If you want to get it right try this chart;
    https://www.google.com/url?sa=t&rct=...VnCV5acZoryK85
    It is a PDF document and you can easily keep it on your cell phone or tablet.
    2019 F3-S , Black & Silver
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    There are two main parts to a screw type fastener. The screw material and the tapped hole material. A steel screw into a steel tapped hole gets one torque while a steel screw into an aluminum tapped hole requires another torque.
    I know that did not answer your original question directly, but it is something to consider in the future.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    May 2018
    Chateauguay, Qc, Canada
    One should also consider the material being crushed between the bolt and nut.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
