Originally Posted by h0gr1der
I just had SpyderPops install the Baja Ron on my RTL. THe other brand looks cheaper, but I believe they do not include the end links in their price. I think it ends up being a wash in the end. I can say the Baja Ron bar is one of those things that makes you say "Why didn't I do this sooner"? That's for the RTL, which is kind of a barge. The F3 may be different.
Can-Am Spyder F3 Performance Sway Bar Kit with Billet Aluminum End Links
Quote from website:
"The Spyder Extras Sway Bar (Anti Sway Bar) kit is the perfect solution for the Spyder rider that would like to enhance their Spyder's handling abilities under aggressive riding. This Spyder F3 sway bar kit comes with an upgraded sway bar, Billet Aluminum End Links & replacement bushings"
$199.95
Quote from website:
$199.95
Mr. bcraig,
I stand corrected, good catch. That's about $89 cheaper than the Baja Ron. When I was looking they did not include the ends as I remember it.
h0gr1der
