Results 1 to 10 of 10
    Apr 2015
    waterford new york
    Post 2014 RT brake failure
    I have a 2014 RT seem to be getting a brake failure and the screen turns orange. Any idea where to look Pads look good fluid level o.k.
    Sep 2017
    Durham,Maine
    Are you getting ay codes?
    2012 RTL , Pearl
    Apr 2015
    waterford new york
    All i get is the scrren goes orange and says brake failure. Where would i look for any codes?
    Sep 2017
    Durham,Maine
    you say it's good on fluid but all it takes is a cap full to make that light go off. Other than the light are you getting any other things going on?
    2012 RTL , Pearl
    Sep 2017
    Durham,Maine
    try to put just a splash more fluid in the tank and see if it goes away! Good luck I had the same thing happen
    2012 RTL , Pearl
    Default Brake failure
    with mikey - almost all B.F. codes are from low fluid ….. the sensor is Extremely sensitive and it's really hard to tell Exactly how much fluid is in there …. add a capful to each reservoir ( clean before opening ) and see if this resolves the problem ….. also make sure the caps are on correctly ( arrows ) …… Mike
    Default Little checking.....
    I agree with the checking fluid level as it is a common issue. Other common problems we have seen with this is folks ryding with their foot on the brake pedal and sticking brake light switches. If things clear after a re-start and don't come back on shortly could be the flluid level if it comes back on after ryding for a while it will be something else. Start with the fluid level ....
    ​2012 RS sm5
    Sep 2013
    Houston
    To get the codes, with the orange screen displayed and the bike on but not running, do this:
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2014
    Mint Hill, NC
    Use a good flashlight to verify the fluid level in the master cylinder reservoirs and be certain the caps are reinstalled with the vents properly oriented, at about 5 o'clock when sitting on the bike with 12 o'clock being dead ahead. The pictures of the caps on pg 135 of the operator's guide do not give a good representation of the vent orientation
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Joerolwing's Avatar
    May 2016
    Nashville, TN
    I just had to replace the two master cylinder caps on my 2014 RTS because the o ring in them was deteriorated to the point of leaking.
