Results 1 to 9 of 9
    Aug 2019
    NC
    Default 2018 RT Daily Driver. 867 miles & squeaky brakes!?
    Any day I can ride is a good day. As the subject states I have a 2018 Spyder RT and it is my daily driver. I have really squeaky brakes and it drives me crazy. I got the bike three weeks ago and it wasn't squeaking initially. It has gotten gradually worse. Is this normal through break in?
    Mar 2015
    forrest above Reno, Nv
    Take it to the dealer where you purchased it---- must still be under warranty.
    2014 RTS , Circuit Yellow
    Aug 2019
    NC
    That is over three hours away. If I have to I will but is there anything I can do myself to alleviate this?
    Default Cleaning a bit....
    You can try cleaning the disc with brake cleaner and blowing compressed air around the calipers to clear away the accumulated brake dust. Many have used Simple Green to clean the brakes. This would be the easy quick thing to do but if your so inclined you can do more like beveling the pad edges, cutting groves in the pads etc. I think the cleaning will do the trick.....
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    Sounds like dirt to me.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Try this, I edited this post - we do not have floating disc - thanksNavydad.
    *only on the back of pad*
    https://www.youtube.com/watch?v=6-lsHL_9GWI
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by bluewoo View Post
    I don't think the RT has floating discs.
    A small amount of brake grease on the BACK of the pads where they contact the caliper pistons can take the squeal out of brakes.
    2015 RT , Black
    Sep 2018
    greensburg,pa
    Quote Originally Posted by Navydad View Post
    Your correct - mine does it also, doesn't bother me.
    2018 RT-L , Blue
    Sep 2014
    USA
    Try A few good hard stops while not locking up the brakes.
