Results 1 to 25 of 28
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Default What weight oil?
    My 2015 RT Ltd. calls for 5W/40 semi-synthetic oil. I will be using full synthetic and at least 10/40. I would like to use 20w/50 since it gets kinda hot here in Florida, even in the winter. Any great damage or terrible terribles if I go to the 20w/50?
    Nov 2015
    Myerstown, Pennsylvania
    I'm sure others will reply but 20w50 I think is a bad idea. Stick with 10w40.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Oct 2014
    Fort Mill, SC
    Weight is only one thing to look at. Make sure you have the correct application specifications. Never use "Energy Conserving. "
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Houston
    20w50 is too thick for a dohc engine with long, hydraulic tensioned timing chains.
    5W40 is the correct weight for use up to 125deg F. Does it get hotter than that in Florida?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    How much more do you know about the Rotax 1330 ACE engine than the engineers who designed it? Reread the left column of pg 123 of your operator's guide, specifically the API service codes and the warning notice.
    Feb 2012
    Spring City,Utah
    5w-40 is what is called for. Shell Rotella T6 synthetic meets this spec. So do many other oils. 20w-50 in unnecessary. Use the weight recommended by the maker.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    INDIANA, USA
    Default Engine Oil
    Use 5W40 oil as per your OM....
    ENJOY YOUR LIFE WITH A SPYDER
    Sometimes manufactures sell what they have and not necessarily what is best. 10w-40 is a better fit for the Spyder unless you need to leave it outside overnight in sub-zero temps.
    I know we are talking about the 1330 ACE motor here. But for example; the 998 Rotax was originally used in the Aprilia. That same exact motor (with the exception of some tuning differences) required 20w-50 oil. But in the Spyder, BRP recommended 10w-40 because that is what they sold. Then, when they went to a 5w-40, that weight oil was recommended because they no longer carried a 10w-40. BRP covers everything from Snowmobiles to water craft with a small line of lubricants. Their lubricant line used to be much more expansive.
    While the oil that BRP recommends for the Spyder is adequate. It is far from ideal. It is a Castrol oil which you can buy at Wal-Mart for a lot less, though you won't be getting it in a BRP bottle.
    It's the upper number that is most important. Not that the lower number does not matter. But you're going to spend 99.9% of your miles relying on the upper number to remain constant. Which it doesn't. Oil quality is the determining factor as to whether the specs can be maintained and for how long.
    I have hot climate customers using 20-50 oil in their Spyder without issue. I still think 10-40 is a better fit for the Spyder. You're not going to be racing it, wide open throttle all the time like the Aprilia, nor will you be having it sit in sub-zero temps very often as would be the case with a snowmobile.
    Nov 2012
    North Las Vegas, NV
    I live in Las Vegas (gets hot here too) and 10W40 Amsoil does a fine job here.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Your choice...
    While living and working in both Texas and California we used 20w-50 on all the bike we sold. Texas did get pretty cold during the winter but never an issue. At best a recommended longer warm up and you were good to go. To be honest.... have not seen any oil related failures outside of clutch issues for the wrong oil used or contaminated oil from fuel/coolant leaks. Middle of the road use the 10w When I lived in Florida I always used the 20w-50....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    My 2017 GMC Sierra 5.4 uses 0W 20. That large engine requires the thinner oil to flow past something (sorry don't know the name of the part) and if you use a thicker oil, it will not flow and the engine will miss. Just mentioning that thicker oil may not be better. Just sayin', go with the manufacturer and you'll not have a problem,
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    L
    Quote Originally Posted by SteveLaoyster View Post
    You think it’s a bad idea tell us why
    May 2016
    P
    Quote Originally Posted by Baron14y View Post
    No it’s ok to use 20/50 I use Amsoil V Twin Racing Oil you can go the full recommended 9200 miles with this oil
    May 2019
    Windsor
    I have been using 10W40 semi synthetic Diesel oil in my wifes 2010 for years now and it works great. I change it every season along with the filter. The specs on Diesel oil are better than most motorcycle oils higher sheer resistance and viscosity drop.
    Jul 2016
    australia
    we had a post in aus about this not long ago and a brp aus master tech says he seen the wet clutchs have issues using car engine type oils.to the point of needing a clutch repair.the rating he mentioned was jaso ma 2.i did a bit of checking and its a thing that gets overlooked.i spoke to a few bike shop here and they all said to use jaso spec oils with wet clutch packs.apparently it helps the clutch packs more so than the engine.and yes he recommends using the oem spec oil.apparently its the friction modifiers used in car type oils that cause the issues.
    i have always used a full synth valvoline oil in my 2014 rt ltd.i scanned it with buds the other day and got a clutch synchronisation error that had been in history for a while.he thinks may be due to the car oil i use.so im swapping over to jaso spec oils from now on.
    SoFlo
    Live a bit further south than you, so it does get hot here. Mobil 1 10w40 4t motorcycle oil. Certainly shifts better and is one of the better rated oils by a very experienced and truly independent source. Rates better than the Rotella and other oils mentioned here. When I last checked, the applicable Amsoil had not been tested.
    Having the multigrade oil with a narrower spread typically tends to increase oil resistance to shearing. These engines could run total crap oil and be fine. The gearbox is what destroys the oil and requires the best protection. Yes the cam and lifter setup is not easy on oil, but the gearbox is worse.
    Run what you prefer, but 50wt seems excessive, even to save the gearbox. Also the clutch will be more sluggish to clamp tightly.
    Feb 2012
    Spring City,Utah
    Stu your tech is correct in that many car oils have friction modifiers. Always look for the JASO MS 2,that will ensure that your oil is wet clutch safe. In the US Shell Rotella T6 is a good inexpensive car/diesel oil that is also rated JASO MA2 and works very well I our Spyders. I am sure there are similar oils in Australia. Peter you know more about what's available in Oz.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Vermont
    Default Oil Question
    I have a 2014 RTS-SE6 spyder and I use Valvoline 4T 10 W -40 full synthetic oil motorcycle oil in my spyder.
    My Question is: What does the "T" stand for?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    NorCal - Northbay
    Deanna
    It "loosely" refers to "stroke", as in four stroke vs two stroke.... Don't ask me why they chose a T for this designation!
    Chuck
    Nov 2018
    Waynesboro, PA
    T stands for technosynthese which is an additive to make your gearbox run smoother. 4 = stroke, T = Synthetic
    My Spyder
    2012 RTL , Brown
    Vermont
    Quote Originally Posted by hypurone View Post
    Thanks! In Oct. my spyder goes in to hibernation until next year ( From Oct.to April) during the winter months. Then I am on the sleds from Dec. to March.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Quote Originally Posted by CopperSpyder View Post
    Question: I have the Valvoline 10 W 40 Full Synthetic ,Motorcycle Oil, with out the 4 T. Can I use the 10 W 40 Full Synthetic Motorcycle Oil with out the "T"?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Nov 2018
    Waynesboro, PA
    Deanna
    AS loge as it meets or exceeds the rating in your manual for the 1330 I think its SN. here is a good article on oil https://bestsyntheticoilguide.com/sy...le-oil-review/
    My Spyder
    2012 RTL , Brown
    May 2019
    Palm Bay, Florida
    Deanna
    As long as it says "motorcycle oil" and meets JASO MA/MA2, you will be OK.
    SoFlo
    Deanna
    4T means 4 stroke, not 2 Stroke, thats all.
