Tri-Axis Bars
I'm not familiar with the Tri-Axis bars that can go on RTs, but has anyone heard whether they could somehow be used on F3s?
Not possible as the handle bar set up are totally different.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Ozzie Ozzie Ozzie
I'm pretty sure the F3's run bars much like any other motorcycle, while the RT's have a steering shaft & the RT Handlebars fit onto it in much the same way a car steering wheel fits onto its steering column/shaft.... so No, the RT Tri-Axis bars won't fit on an F3, but there is quite a range of different reach bars available for for the F3, some risers & other methods of adjustment too, and I believe using any of those options will be a fair bit cheaper than the Tri-Axis bars too!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Nope, completely different mounting and geometry. If you are having trouble you may need to consider different/custom bars or the various bar extender products you can get on the market.
Rob
2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
Well, that settles THAT pretty thoroughly. Thanks to all. I was merely wondering.
