Results 1 to 2 of 2
Thread: Loose airbox
    Jun 2019
    Ottawa, Ontario
    Default Loose airbox
    Hi there,
    I'd never noticed this today so it may be normal but...
    Does anyone else have a bit of play in the airbox (drivers left) where it will have a bit of play in it? I took off the cover and the air filter holder and the actual box can move a few mm from what seems like the top. There's a bolt on the bottom left and a pin on the right. Bolt is tight but I can't quite see the top.
    As I say, could be normal and it's just I've never noticed it before but I did a long ride today and noticed it moving around a little (some of the roads were insanely rough).
    Normal or anyone else have this?
    Jun 2012
    Nevada
    Quote Originally Posted by guppy View Post
    Hi there,
    Yes mine is that way also.
    Seen a post awhile back with same complaint.
    Seems secure enough it won't fall off.
