I was changing rear tire and shock and I watched finless’s video and he mentioned a sensor needed to be unhooked prior to but there was no sensor there. There is still a a place to mount it but no sensor.
Is it that 2015 RS did not require that sensor or possibly been moved?
I see. thank you
rear tire change is much easier now with self=contained rim, no hub to remove and less things to contend with.
check bearing on both side and you are done.
I am not sure why parts scheme still shows removable hub.
