Results 1 to 6 of 6
    Apr 2016
    St. Charles IL
    Default Ipod and AUX cable
    Just brought my '19 F3 LTD home today! Traded in my '16 RT-S. WOW! What a difference! Anyway, I'm trying to play my Ipod through the USB plug in the glove box. NOTHING! I just read that if I plug the RCA jack that's in the glove box into the headphone jack on my Ipod it should work. I thought I'd ask here first before I tried it.....
    Any thoughts??
    Jul 2011
    Mitchell, Ontario, Canada
    Not designed to operate a ipod directly any more. You can plug in the aux cable. But you cannot control it by the handlebar controls.
    If you have a smart phone. Use that instead through BT.
    Apr 2016
    St. Charles IL
    Is there only 1 Aux cable on the bike? I took my XM radio off my RT hoping to put it in the LTD. I thought there was a cable under a panel on the left side somewhere......
    Jul 2011
    Only one aux and it is located in the glove box aka pizza oven. The other input you are thinking about is the gps audio. It's gone for 2018 and 2019.
    Apr 2016
    St. Charles IL
    Ok, after doing a little research this is the hook-up:
    Connect XM unit to USB plug (lamonster for power plate and Amazon for cord) for power
    Connect XM unit to AUX cable in glovebox (using a female to female adapter)
    Connect XM antenna to unit
    Should work, yes?? (Have to fix signature)
    Jul 2011
    Yes that should work.
