Originally Posted by teninospyder
I had a story already in print about how this got from Silver to Gold to BRP Cognac (VHT SP402), but the site decided my commands obviously weren't right for attaching pics and deleted the whole thing before I could send it. So, in short, Thanks to Pete Nixon for selling me this trailer and bringing it with him to Mt. Rainer area from Utah, and Thanks to BLUEKNIGHT911 for helping me with some concerns/procedures about using this paint. My "significant other/soul mate/all time riding partner" is also happy that I considered her request to repaint it from the Gold we originally agreed on Life is good
PS: sorry there are 2 of one pic here
Great job with that! We enjoyed meeting you for the first time in Morton, WA and look forward to a time we can tour the Olympic Peninsula together. You live in a beautiful area.
2014 RTL Platinum
Ozzie Ozzie Ozzie
Lookin' Good!
Cognac Trailer
Glad I could assist …. it does look great ….. we discussed clear coating the base color …. Did you ???? …. Mike
Nice looking trailer.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Not yet. Do I need to wait a few days?
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
I have the same setup you have. I looked into a wrap but it was bucu expensive. More than the origional cost of the trailer. How many cans did it take to do the job? Any pit falls to watch out for? By the way, you don't mind if I copy your process do you?
Well you PM'd me that the VHT can advised 7 days …. I think they know their product best …. I think clear coat would make the color deeper and also protect the color coat ….. Mike
OK, 1 week it is. If I can wait that long
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
Be sure to test a small inconspicuous area with the clearcoat first. Clear it and wait an hour to make sure there is no clearcoat lift or wrinkling.
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
teninospyder, nice job, very nice.
Looks awesome! Enjoy the ryde!
Raprider (Rich)
2016 Can-Am Spyder ST-S SE5 Steel Black Metallic ( Blackbird)
BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
Kumho Ecsta AST installed on rear 4/2021
1996 Yamaha Virago 750 (Vera) - still riding
1987 Honda Shadow 500 (Shady) - sold
1982 Honda Rebel 250 (Little Reb) - sold
Yes, the clear coat makes the color deeper, and it protects the clear coat.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Wow...!!
Nice job... can you get chrome wheels for the trailer...? Would give it that finishing touch...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Thanks to Mike (BlueKnight911) for coming up with this solution. Here it is on Amazon; https://www.amazon.com/VHT-SP402-Eng.../dp/B002NUFVRW
VHT SP402 Burnt Copper High Temp (650 degrees Fahrenheit) Engine Metallic has excellent durability and superior heat and chemical resistance. It is specially formulated to withstand corrosion, rust, salt spray, chemicals and additives of today's gasoline blends and degreasers. VHT's Engine Metallics is a unique blend of urethane and ceramic resins, which produce a long-lasting finish for engines, engine accessories or wherever a tough durable heat and chemical resistant finish is needed. Engine Metallics coating creates a cool sparkling metallic finish and withstands intermittent temperatures up to 650 degrees Fahrenheit. VHT SP402 is part of a multi high performance coating system for the ultimate protection and quality. The coating system products consist of surface prep, engine primer, engine metallic, and engine clear. VHT Engine Metallic coating dries to the touch in 30 minutes and completely over night. VHT Metallic coating only attains its unique qualities after correct curing. Curing occurs with normal engine operating temperatures or parts can be heated to 200 degrees Fahrenheit. Complete application and curing process instructions are also printed on each can.
2014 RTL Platinum
Thanks ….. but an important footnote …. this paint is formulated for METAL , so it will eat PLASTIC ………. NOT an issue as long as you completely PRIMER paint the plastic ,,, the VHT has NO bad effect on the Primer paint …… Mike
I was wondering about that very thing. Thanks!
2014 RTL Platinum
