Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Aug 2019
    North Carolina
    Default 2014 RT Limited Questions
    Greetings all , I just purchased a 2014 Spyder RT Limited and wanted to add a couple of accessories .
    I want a GPS and I want to be able to listen to Pandora via my Iphone (Bluetooth) but through the Spyders speakers .
    Looks like I need a Garmin Zumo 590GPS part # 219400512
    A GPS mount kit for stock handlebars part # 219400615
    A Bluetooth Dongle part # 219400458
    And I guess a Ram cell phone mount
    Anything else needed to accomplish my goal ?
    Thanks in advance, Pete
    Jul 2014
    Mint Hill, NC
    The '14 Ltd came with a Garmin 660, where'd it go? You will like the 590/595 though; it's a newer model.
    Get yourself a Kradellock for the GPS and relieve yourself of the hassle of removing the GPS every time you leave the bike -- that is unless you like to live dangerously. https://robertbeckerdesign.com/shop?...kradellock-659
    You can get the Sena SM10 and harness from Motorcycle Dave at substantially lower cost
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2019
    North Carolina
    Very interesting. Just made the agreement to purchase yesterday so I have not gotten the bike home nor have I seen it in person.
    Just texted the current owner, he says the gps mount is there , hopefully he can locate the head unit.
    Thanks for the info .
    Nothing I can add except and
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    I went through trying to figure out a lot of this when I got my first Spyder, and ended up using helmet bluetooth speakers and my iPhone for GPS and audio.
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Jul 2014
    Mint Hill, NC
    To make sure we are on the same sheet of music, the GPS mount is the part that bolts to the handlebars. The GPS cradle is the part the GPS snaps into and has an integral wire harness that connects to the Spyders wiring harness. The GPS cradle is bolted to the GPS mount. FWIW, the cradles for the Zumo 660 and 590/595 are different and not compatible.
    Cognac 2014 RT-S
    Aug 2019
    North Carolina
    Yeah , I get it. Appears that the current owner has "misplaced" the Zumo head unit that snaps into the aforementioned mount and cradle.
    It also appears that there are still some 660's available out there on ebay and such. Hopefully he will find it or else we will have to make some adjustments.
    If I replaced it with a 590 the mount and cradle would need to be replaced ? What about the harness , would the one from the 660 work ?
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by petew View Post
    ...If I replaced it with a 590 the mount and cradle would need to be replaced ? What about the harness , would the one from the 660 work ?
    If you purchase a 590/595 it will come with its own cradle. The cradles for the 660 and 590/595 are different and the 660 cradle will not work with the 590/595. The configuration of the pin connections on the two GPSs are different. FWIW, when I purchased my '14 RT-S in Sept '14 the standard Zumo was the 660 and dealership did not know what the GPS for MY 2015 was going to be. At my son's advice I opted for the Zumo 590 as the 660 had been around a long time by then. The 590 was the GPS for MY 2015. I like the 590 very much and it has been very reliable.
    Cognac 2014 RT-S
    Aug 2019
    North Carolina
    Ok picked up my Spyder from Georgia a couple of days ago . Having been a motorcycle rider for 40 years the transition to this was simple and I love it.
    The 660 Zumo GPS that came stock on the bike was not found so I am moving forward with plans to replace it with a Zumo 590 . The factory 660 mount , cradle , cover , and wiring are on the bike. So if I replace the 660 cradle with a 590 cradle will the existing harness from the 660 work or will that need to be replaced too ?
    I am going to call Motorcycle Dave about the Sena SM10 on Monday.
    MRH thanks for your input but I was this all to work on the Spyders audio system.
    Jul 2014
    Mint Hill, NC
    The 590 cradle will come with its own cradle and harness. Under the Tupperware somewhere the old 660 harness will unplug and the 590 harness will plug into the same connectors. I do not know exactly where because the dealership hooked up mine.
    Cognac 2014 RT-S
    Aug 2019
    North Carolina
    Good deal , thanks
    Dec 2015
    Oakley Utah
    Suspicious. Would not trust this seller.
    2014 RTL Platinum
    western Colorado
    Just because you misplace something doesn’t make you a bad person
    Aug 2019
    North Carolina
    The sellers only problem is that the Spyder was a toy that he didn’t pay much attention to .
    He owned it over 5 years and only put 500 miles on it. On top of that I got a great deal on what is essentially a new bike.
    I have no complaints and chose to not make the missing gps an issue. I got a real value here even minus the gps.
    After 33 years as a law enforcement officer I’m a pretty good judge of character and the seller was ok. If I had the garage full of vehicles and huge house that he had I might have misplaced the gps as well.
    Nov 2013
    Oro Valley Arizona
    Get a 665. It will eliminate the Dongle and you can listen to XM without it. The 660 is not capable of XM with out the Dongle.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I had the same issue - the PO didn't pass the GPS along when he traded in the tryke. So I have a cradle (don't know for what model GPS) and mount on the handlebars. Also there's a cable undr the side cover that seems to be part of it - it has a plug labeled "helmet" on it. Not sure what that it or what its for. The mount is coming off as I don't intend to use it, but I need to get new bolts for the handlebars first. Already removed the XM and Sena SM10H.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Aug 2019
    North Carolina
    Alright I think I have the necessary parts coming for the GPS swap , now onto the music portion of our show !
    I am not the sharpest knife in the drawer when it comes to electronics so I am having a problem understanding exactly what I need to buy to accomplish my goal , or if my goal can even be accomplished.
    As stated earlier I want to be able to play Pandora from my iphone through the Spyders speakers , Not through a bluetooth helmet headset or earbuds .
    It seems like the Sema SM-10 is not designed to do this , that's what I gathered from the youtube videos I have watched. Now I know there is a jack in the trunk to connect an Ipod but the end doesn't conform with the iphone.
    So the question is does a method exist to wire the phone into the existing stereo system ?
    I only want to hear Pandora , no phone calls or anything else . I don't need or want a helmet communication system .
    Any spoon feeding that can be provided on the subject would be greatly appreciated.
    Pete
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Pete
    Get a bluetooth transmitter from eBay, Amazon, or somewhere else. You can stick the transmitter in the rear trunk and keep it charged up.
    If you didn't accessory get the cable from the original owner then you will need it also. The picture shows my setup - dual port USB adapter plugged into the power adapter, BT device plugged into power and the accessory cable which makes it play thru your speakers.
    https://www.ebay.com/itm/Bluetooth-V...YAAOSwOHpcRn2N
    https://www.ebay.com/itm/3-5mm-Stere...72.m2749.l2649
    https://www.ebay.com/itm/12V-Dual-3-...LPki3rdtdySk6A
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Aug 2019
    North Carolina
    Now that sir was some good spoon feeding ! Thank you very much.
    I do have the accessory cable .
    That looks like a very simple and inexpensive way to attain my goal .
    Thank you for sharing your knowledge.
    Jul 2016
    australia
    theres a guy on ozspyderiders call merlot thats selling a zumo and cradle,not sure of the model though.hes on here too i believe
    Dec 2013
    Quote Originally Posted by stu View Post
    For anyone interested, Merlot's now got a thread posted in the 'For sale by Owners' section offering his Zumo (590 LM?) for sale with all the necessary bits for mounting on an RT....
    https://www.spyderlovers.com/forums/...M-Mount-for-RT
    Over to you!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jul 2016
    australia
    thanks peter for clarifying that model number up.and the link post
    Mar 2019
    Central SC
    That's pretty much what I ran into with the Sena on my tryke - it's for hooking the output of the stereo/xm/gps into your BT headsets, not for hooking a BT player and running it through the built in stereo. Now I just use the Cardo BT setup and don't use the speakers anyway.
    2014 RT-S , Orange
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Forget the BRP dongle.
    IF your main objective is Pandora through the iPhone go with this and save a bundle of $$$
    LinK BT06 Car Wireless Bluetooth V4.1 Audio Receiver Music Adapter with Hands - free Calls / 3.5mm Stereo Output
    https://www.amazon.com/MITUHAKI-Wire...y&sr=8-1-fkmr2
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Aug 2019
    North Carolina
    Quote Originally Posted by al0vely View Post
    Well sir that worked as advertised !
    Got about $12.00 worth of electronics from eBay ,hooked it all up as per your pictures and I now have Pandora playing through my Spyders speakers .
    Thank you very much !
    Pete
