Results 1 to 15 of 15
    Active Member bcraig's Avatar
    Apr 2019
    Grove City, OH USA
    Default Anyone tried SSV Works Dual 6.5" Bluetooth Audio System?
    Has anyone installed this system from SlingMods? What is the quality of the sound and the product itself? Are there better less expensive systems that you would recommend.
    This would be for a 2019 F3 Base model.
    Mar 2017
    Dec 2019
    San Antonio, Texas
    Looks like no one responded to your post. I'm a new spyder owner (2019 F3 base) and awaiting my SSV Works system to be delivered tomm (12/29/19). I will attempt to install very soon and give you a detailed review of the system along with pics.
    Thanks Arcamguy
    2022 RT , Marsella Red
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Quote Originally Posted by bcraig View Post
    Easy install, just follow the instructions. I upgraded to the Kicker speakers. Excellent sound and loud if that's what you're looking for. If you plan to use the AUX for sat radio or other item you will have to order the adapter sold by SSV Works. It does not come in the kit. There's no place to plug in a 3.5mm cable without it. Not needed if using Pandora.
    Sep 2013
    Houston
    I have the system on my F3. Well made, quality sound far better than my wifes Harley Boom audio. Very nice the way SSV designed the install to not use any trunk space. Also I have heard both the SSV weather resistant speakers and the Kicker speakers on this system and there is VERY little difference in sound between them. Both good but with the SSV speakers having a lifetime warranty and $100 cheaper, I suggest saving your $$ on the speakers option. My kit came with the adaptor for plugging in a 3.5mm audio cord but I have no use for it as I use only bluetooth. Also set mine up to turn off with key off as well rather than always powered on.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Dec 2019
    San Antonio, Texas
    Finally got the bugs worked out of my install, so relieved. How did you get it to just go on only when the key is turned to the on position.
    Thanks Arcamguy
    Sep 2013
    Houston
    I installed a relay in the power to the amplifier. Used a running light circuit to trigger the relay. The SSV works radio does not forget bluetooth links when its power is cut. It does reset volume to a lower level.
    Dec 2019
    San Antonio, Texas
    Sep 2013
    Houston
    Quote Originally Posted by Arcamguy View Post
    I can tell from your photos that you have the speakers installed leaned back further than I do and may be why you are seeing the back edge of your housing so close to the bike body work. I think you have the mounting brackets mounted to the speakers in a different index position than called for.
    Mar 2019
    Fla/NJ
    this is my setup came on bike. would like to know who made it
    Feb 2020
    Arizona
    mixed information on what windshields work with this setup, anybody have input on what will work?
    Mar 2019
    PG BC
    Quote Originally Posted by honsfun View Post
    https://mbquart.com/
    Here is the link to MBQuart . Thats who made the speakers , looks like some high end stuff but the small fairing it's mounted to I couldn't find on their site . Might be a custom job ?
    2019 f3-s , Blue
    Sep 2013
    Houston
    Quote Originally Posted by AzBTO View Post
    I have mine installed with an F4 Customs windshield.
    Aug 2019
    Stoughton, WI
    Reviving an older thread. Are you still using the SSV system on your F3? Are you happy with it? I'm half ass pondering getting one, but past experiences albeit years ago, have proven less than good results. I'm not expecting clear audio at interstate speeds, but hoping half decent at normal highway speeds. Experienced input please Thx
    2022 RT Sea To Sky
    Member Duane224's Avatar
    Nov 2021
    Michigan
    I've installed the SSV Works on my bike this past weekend. It really throws some sounds. I broke down and added 2 more speakers.
