Results 1 to 24 of 24
    Aug 2018
    Thousand Islands
    Default Any after market license plate lights for F3's?
    Lost the red license plate cover on my F3 and instead of spending $50 to get another one from brp i was wondering if anyone has found something better that will fit on F3 ?
    2015 Canam Spyder F3-S SE6
    Detachable Passenger backrest #219400703
    Gauge Spoiler #219400531
    Blue Ridge Windshield #219400746
    Hood stripes decal kit #219400711
    F3 Idler Pulley #219800431 / Lamonster roller upgrade
    Bajaron SwayBar
    Elka Stage 2 rear shock
    Arc LED fog lights
    Lamonster F3 bar clamp with Quad-lock phone mount
    Foam Hand Grip Covers
    Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
    My touring partner lost his a couple of weeks ago. IMO, it's a s***ty design. In a recent thread several folks have offered their approaches to prevent it from happening again. Here's an idea: https://www.youtube.com/watch?v=jUvn...ature=youtu.be
    Aug 2018
    Thousand Islands
    Thanks, I dont think im putting another brp one, i was hopping someone may have put an after market already so i dont have to go through trial and error
    Bajaron SwayBar
    Arc LED fog lights
    Aug 2015
    Northern KY, Butler
    I am confused now, Lost mine Saturday and it seems to just be a cover plate cap that is held on with 1 screw. For the cover you have to purchase the entire assembly???? What a crock. I am now back on 3 wheels for a new to me 2015 F3-S. It is so much fun and I do like it a bunch.
    Aug 2018
    Thousand Islands
    Quote Originally Posted by RosieriderKY View Post
    Yes you have to order a whole new assembly and not only that but you have to take the rear fender apart to replace it.
    Bajaron SwayBar
    Arc LED fog lights
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    If you are talking about the license plate light, check either TRICLED or Custom Dynamics, I replaced the one on mine but I can't remember the source.
    Aug 2018
    Thousand Islands
    You still need the original cover that i lost
    Bajaron SwayBar
    Arc LED fog lights
    Aug 2015
    Northern KY, Butler
    It sure seems to me that this could be an inexpensive fix, $$15 or so. All it needs is a plastic or thin metal rectangular cup with screw hole in bottom middle to fit on the part that does not fall of and run away. My new $50 fender cover should be here tomorrow. I will take the cover piece off and Loctite it like crazy in hopes of saving another $50. I would really feel bad if I lost another one on my less than a week old to me F3.
    Oct 2011
    dunnellon fl
    loctite wont do it. the boos area for the screw is to thin. i thought someone stole the first one. bought 53 dollar new one (yikes) and used a longer anti theft screw. it lasted about 10,000 miles and it was gone. the plastic just breaks around screw. i gave brp the riot act and they just looked at me. buttheads. they have no plans to help us out.
    [SIGPIC]
    Houston
    Quote Originally Posted by donhy View Post
    No, Custom Dynamics makes a replacement cover. This has been an issue on the Spyders since the first GS models. Incidentally the F3 uses the same tail light assembly as the RS. BRP does not sell the lens separately but the aftermarket does.
    When installing the replacement lens, suggest a dab of black weatherstrip adhesive on the 4 corners of the cover where it joins the housing. The single screw rattles loose and falls out easily.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Way back when this issue started to occur ( GS _ RS ) some folks tried using Lok-Tite , and I believe the Lok-Tite …. ATE … the plastic, not immediately but in a short time ….. so if you all ready put it on …. dis-assemble and clean it ALL off …. then do what JC said ….. good luck …. Mike
    Aug 2016
    Sun City West, AZ
    I used a dab of clear silicone on the screw threads in lieu of Loctite and it worked well, two years and the screw is still tight.
    Dec 2012
    Murphy, NC
    Custom Dynamics no longer sells the replacement lens.��
    2020 F3 Ltd
    Spyderpops Bumpskid
    Mar 2017
    Hot glue will work as non-corrosive thread lock.
    Aug 2015
    Northern KY, Butler
    still working on this, ordered the wrong part so had to return the fender molding and reorder the license light assy. Just an FYI Bike Bandit and other places have this available and might be easier to deal with that Spyder shop. I like BB as they are priced ok and service is good. Still working on aftermarket or even home made solution for my retirement mission. How is it that a manufacture does not offer a lens??? Can Am is so frustrating sometimes. But they have a product that is unique and provides a great ride option for those of us that appreciate the 3 wheel solution to riding.
    Aug 2018
    Thousand Islands
    I searched the entire internet and couldnt find after market replacment lens so took the opportunity to add some extra lights at the same time, ive ordered few different led license lights that i think at least one of thek should fit nicely and lot more brighter than the reflective brp lens. They were quite cheap from China so probably the whole thing will cost me less than the brp assembly just more labor intensive
    Bajaron SwayBar
    Arc LED fog lights
    Aug 2015
    Northern KY, Butler
    I like it and think about anything would be better than the stock set up.
    Active Member ATitus's Avatar
    Jul 2015
    Crown Point, Indiana
    https://www.ebay.com/itm/Black-catey...gAAOSwWhVbwmkG
    Here’s what Lamonster recommend to me and it looks nice on the Spyder!
    Life is GOOD...............
    2015 F3S
    SmoothSpyder backrest
    lidloxs
    Gloryder F3 Logo Lights
    Lamonster mirror relocations and turn signals
    Lamonster fog light kit
    Lamonster Power Plate
    X Grip
    Ram mount
    Aug 2018
    Thousand Islands
    So it took a while but got my aftermarket $9 led light from China which is much brighter better made.
    Bajaron SwayBar
    Arc LED fog lights
    Active Member DunaJ's Avatar
    Feb 2013
    Rowlett, Tx
    Where did you purchase aftermarket tail/license plate light?
    Aug 2018
    Thousand Islands
    Bajaron SwayBar
    Arc LED fog lights
    Jan 2016
    Texas
    That link does not work!
    Quote Originally Posted by Tycott View Post
    Possibly because the post with that link in it is now almost a year old!
    Sorry.
    Aug 2018
    Chicago
    its not the screw , lost mine syder fest thin plastic screw stay there but plastic breaks brp
