lid locks and mirrors
Can you use lid locks with the bar end mirrors? Thanks Bob
Best to ask lidlox about that.
Their website says yes but real life experience doesn't hurt.
I think Lamonster was working on a mirror that would work with the Lid Lox.
I have the lid lox installed on my RALLY with the bar end mirrors. They were purchased from Lamonster. No problem with the install, I used the longer bolt that was supplied with the kit.
Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
I am also using Lidlox with the factory mirrors. No issues....they installed in a few minutes.
Yes you can. The stock mirrors have an insert into the bar ends that has a nut inside of it. You can use the same stock bolt for the LidLox kit. Just pull the bolt out and use the lidlox assembly as you normally would. Very easy
