Results 1 to 23 of 23
    Mar 2019
    GTA, Canada
    Default Anyone got a rear tail/brake stobe effect set-up?
    Making a separated thread as suggested (from my cluster glass issue).
    I am thinking to add a module for the rear brakes that will strobe the light (with the hope that I make it more evident for people behind me that I am braking).
    I was looking at this module: Swess GS-100A.
    However this module works for LED bulbs... so I was also thinking to replace the tail bulbs with these:
    https://www.amazon.ca/dp/B07Q21LGQP/...v_ov_lig_dp_it
    If anyone did this (or at least anything similar)... did you had any issues with the setup (CANBUS errors or whatnot)?
    Mar 2011
    oregon
    Quote Originally Posted by mrNewt View Post
    as picky as the can buss system is on these bikes I think you are headed for nothing but frustration
    Mar 2019
    GTA, Canada
    Quote Originally Posted by r1100rider View Post
    Could be... that's why I am here asking the questions.
    Maybe someone did something similar before and there is a way.
    Mar 2011
    oregon
    if a tail light burns out or if you put an led bulb in it will go into limp mode i wouldnt bother not worth the drive home in limp at 30 mph been there done that good luck
    Feb 2019
    Portland, Oregon
    I installed this flasher in the third brake/tail light that's in the trunk. I am pleased with the results, very attention grabbing. I did not use the furnished connectors, don't like that type. Used Posi-Locks instead.
    https://www.banggood.com/20W-LED-Bra...r_warehouse=CN
    Active Member wd8ajj's Avatar
    Las Cruces NM
    I have the TricLED on my 14 RT and have no issues with it. It plugs right into the cables with no cutting. Easy install
    Mar 2019
    GTA, Canada
    I don't necessarily want to switch to LED... if I can find a strobe module that works with the normal bulbs, I am OK with that as well.
    Would you be willing to show some pictures with the setup of your trike?
    Thanks!
    Quote Originally Posted by wd8ajj View Post
    I have the Tirkled on my 14 RT and have no issues with it. It plugs right into the cables with no cutting. Easy install
    Do you have a link? I have to be honest I do not know what is the Tirkled...
    Feb 2019
    Portland, Oregon
    Thanks!
    Mr. Newt.....The bad news is, I didn't take pictures. The good news is, it's so simple. Open the cavity in the top case, determine which of the two wires to the light are + & -, cut both, splice the box into those wires (black is ground) and you're done after putting the light back.
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    I have the Trciled Strobe, it works very well had it going 2 years, also I added the 3rd brake light with strobe and no problems there either.
    To be continued....
    Mar 2019
    GTA, Canada
    What is this "Trciled Strobe"? Did a google search and found nothing .
    Mar 2019
    GTA, Canada
    I will ask again if anyone can tell me more about this "Tirkled / Trciled" strobe light... I did some search but nothing came up :|.
    If not, then I will be going for something else - I have found a module that apparently works with the Incandescent bulbs, so no need for LED lights.
    The unit is called FlashFast 60 Watts... hopefully will work .
    Oct 2017
    Central NJ
    Typo...TricLed...
    Check on/contact www.TricledUSA.com...
    Updated...
    Actually...this...
    https://www.tricledusa.com/product-p...ay-oem-harness
    The Tricled strobe looks exactly like and has the exact same strobe patterns as the RT Magic Strobe that Custom Dynamics used to but no longer sells.
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
    Mar 2019
    GTA, Canada
    Sweet -thank you guys!
    I will have a look, compare and I will be placing an order on one of them sometime this week .
    Jul 2018
    Saskatchewan
    Jul 2018
    New Jersey
    Lamonster Bright tail lighter.
    2018 F3L , Blue
    Mar 2019
    GTA, Canada
    Quote Originally Posted by jlc41 View Post
    Is not really going to work on the RS-S.
    Also, I would like to not add anything extra... re-using the stock lights is ideal...
    Speaking of, I think I will be going for the TricLed option; no additional light, everything seems to be plug and play and its re-using the stock lights (which is exactly what I want).
    Thanks all!
    Mar 2019
    GTA, Canada
    Update... received the TricLED and love it - easy plug and play install, no issues so far.
    Thanks all for the help!
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    how hard is it to install on f3t. i want for my and wife bike both f3t
    2019 f3t , titanium
    Durham,Maine
    Depending on what company you buy from some will give you a point by point work sheet with pictures!! I got the third brake light from spyderpops.com this spring and they gave me a set of directions a five year old could fallow!! Good luck
    2012 RTL , Pearl
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    I like the Hyper-LItes
    Bossier LoUiSiAna
    You can also leave the OEM lights solid & add some modulation lights personally I like the mix. 56B4B727-E5F9-4B25-99BF-E9AF52DA07C5.jpg
    The small LEDs are Rivico & modulate while the rest are solid I found something closer for running the wires than the optional license plate kit provided.
    https://www.rivcoproducts.com/shop/m...bikes/somakit/
