Anyone got a rear tail/brake stobe effect set-up?
Making a separated thread as suggested (from my cluster glass issue).
I am thinking to add a module for the rear brakes that will strobe the light (with the hope that I make it more evident for people behind me that I am braking).
I was looking at this module: Swess GS-100A.
However this module works for LED bulbs... so I was also thinking to replace the tail bulbs with these:
https://www.amazon.ca/dp/B07Q21LGQP/...v_ov_lig_dp_it
If anyone did this (or at least anything similar)... did you had any issues with the setup (CANBUS errors or whatnot)?
as picky as the can buss system is on these bikes I think you are headed for nothing but frustration
2 happy happy spyders
Could be... that's why I am here asking the questions.
Maybe someone did something similar before and there is a way.
if a tail light burns out or if you put an led bulb in it will go into limp mode i wouldnt bother not worth the drive home in limp at 30 mph been there done that good luck
I don't necessarily want to switch to LED... if I can find a strobe module that works with the normal bulbs, I am OK with that as well.
Originally Posted by RICZ
I installed this flasher in the third brake/tail light that's in the trunk. I am pleased with the results, very attention grabbing. I did not use the furnished connectors, don't like that type. Used Posi-Locks instead.
https://www.banggood.com/20W-LED-Bra...r_warehouse=CN
Would you be willing to show some pictures with the setup of your trike?
Thanks!
Originally Posted by wd8ajj
I have the Tirkled on my 14 RT and have no issues with it. It plugs right into the cables with no cutting. Easy install
Do you have a link? I have to be honest I do not know what is the Tirkled...
Thanks!
Mr. Newt.....The bad news is, I didn't take pictures. The good news is, it's so simple. Open the cavity in the top case, determine which of the two wires to the light are + & -, cut both, splice the box into those wires (black is ground) and you're done after putting the light back.
I have the TricLED on my 14 RT and have no issues with it. It plugs right into the cables with no cutting. Easy install
I have the Trciled Strobe, it works very well had it going 2 years, also I added the 3rd brake light with strobe and no problems there either.
What is this "Trciled Strobe"? Did a google search and found nothing .
I will ask again if anyone can tell me more about this "Tirkled / Trciled" strobe light... I did some search but nothing came up :|.
If not, then I will be going for something else - I have found a module that apparently works with the Incandescent bulbs, so no need for LED lights.
The unit is called FlashFast 60 Watts... hopefully will work .
Reason: added specific link...
Raprider (Rich)
2016 Can-Am Spyder ST-S SE5 Steel Black Metallic ( Blackbird)
BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
Kumho Ecsta AST installed on rear 4/2021
1996 Yamaha Virago 750 (Vera) - still riding
1987 Honda Shadow 500 (Shady) - sold
1982 Honda Rebel 250 (Little Reb) - sold
The Tricled strobe looks exactly like and has the exact same strobe patterns as the RT Magic Strobe that Custom Dynamics used to but no longer sells.
My Spyder
Sweet -thank you guys!
I will have a look, compare and I will be placing an order on one of them sometime this week .
Lamonster Bright tail lighter.
Lamonster Bright Ryder, Lamonster Bright Tail Lighter, Lamonster H4 LED Headlights, Lamonster LED Fog Lights, Lamonster Fog Light Ring Combo, Rox Riser
Lamonster Driver Back Rest, Lamonster Frame Mount Drink Holder.
Lamonster 15" Freedom Shield Wind Shield ******* USA flag
Freecom 2 head sets
Mirror Wedgies by Squared Away
Motorcycle Dave's Tachform phone cradle
Spyderpops Turnsignal LEDs
Spyder Sisters Shade
Spyderpops LidLocs
Spyderpops front fender LEDs by Show Chrome
Motorcycle Dave's Gel seat insert
Is not really going to work on the RS-S.
Also, I would like to not add anything extra... re-using the stock lights is ideal...
Speaking of, I think I will be going for the TricLed option; no additional light, everything seems to be plug and play and its re-using the stock lights (which is exactly what I want).
Thanks all!
Update... received the TricLED and love it - easy plug and play install, no issues so far.
Thanks all for the help!
how hard is it to install on f3t. i want for my and wife bike both f3t
Depending on what company you buy from some will give you a point by point work sheet with pictures!! I got the third brake light from spyderpops.com this spring and they gave me a set of directions a five year old could fallow!! Good luck
You can also leave the OEM lights solid & add some modulation lights personally I like the mix. 56B4B727-E5F9-4B25-99BF-E9AF52DA07C5.jpg
The small LEDs are Rivico & modulate while the rest are solid I found something closer for running the wires than the optional license plate kit provided.
https://www.rivcoproducts.com/shop/m...bikes/somakit/
