Results 1 to 6 of 6
    Florida
    Default Installed Bajaron sway bar yesterday at the dealer. And this happened.
    I went out for a night ride and after coming back home, I ducked down and check the sway bar, I spot that the billet aluminium end link on both side was able to move left and right. As I'm new to the Can-am and Bajaron sway bar. I would like to get you guys opinion. Is the dealer installed them correctly or it's not suppose to be moving at all?
    thank you so much.
    Sep 2009
    La Valle, WI
    That is normal. It needs to move with the suspension as it tilts.
    2018 F3 Limited , Oxford Blue
    Florida
    Thanks man!
    Default For sure....
    They are hiem joints and are to give a pivot point to keep from snapping things
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2012
    Southern California (Oceanside)
    So ow did the handling feel after install...improved?
    Florida
    Quote Originally Posted by Thopper View Post
    It a whole lot better!
