Results 1 to 9 of 9
    Jun 2014
    Prescott Valley, AZ, USA
    Default Parking brake problem
    After a ride today we got home, set the brake, indicator light came on, turned off the key. The brake horn sounded off as if I had not set the parking brake. My husband disconnected the battery and of course the horn shut off. He put it back together and all seemed ok. BUT, not so much. He cycled the brake switch with the bike running, we could hear the brake set and release BUT, the brake light stayed on the entire time. Went for a short ride, the brake light stayed on the entire time during the ride, got home, set the brake and heard it set, turned the key off and the parking brake horn sounded. Had to disconnect the battery again...
    Any help would be appreciated, nearest dealer is 85 miles away, in PHOENIX!!!
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Had this happen when my switch started to go bad. Never have had to disconnect battery after about 45 seconds for me and it would shut off.
    To be continued....
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Quote Originally Posted by MaMaBear View Post
    If you can take the right side plastic off, you will see the micro switch on the parking brake drum. Cycle the parking brake and you will see how the switch operates. See if it is moving enough to deactivate or uplug the wire to see if alarm stops. Might just need new switch or motor is not cycling park brake drum far enough.
    2014 RT SE6
    Nov 2015
    Chardon, OH
    Seems like the brake and motor are working correctly. Knowing the year of your RT helps, but I think they all work the same. +1 on the micro-switch. Might just need to lube the little arm and plunger. Check that the arm is not bent or that the switch has come loose. You can operate the switch by hand to tell if it is operating correctly.
    BTW - if you wait until the shutdown of the bike has timed out, the alarm will stop on it's own.
    Doug
    ”Freedom is not a loophole”
    Jun 2010
    Las Vegas
    There have been issues on 18 & 19 RT models, if yours is one then a trip to the dealer is in order.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Dec 2018
    KS
    My 2014 RT literally did the same thing the other day. I thought cause it was hot outside. It only happened the one time. The more issues I am seeing with spyder, the more I am tempted to get a goldwing instead.
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    We used those switches at work ,and they were always giving problems .
    2018 RTL , dark blue
    Jun 2010
    Las Vegas
    Quote Originally Posted by piperpilot75 View Post
    My husband, CPTJAM, rides an 18 Goldwing and it has been in the shop several times for various issues with reverse and hill hold. Maybe he should get a Spyder instead.
    2010 RT- 622
    Jun 2014
    Quote Originally Posted by Snowbelt Spyder View Post
    Can't THANK YOU ENOUGH!!! Husband went out to the garage, pulled the panels off, sprayed the switch with degreaser, and low & behold it works fine now!!! Gonna get some oil and a filter kit and change the oil as long as it's apart... THANK YOU SO MUCH!!!!
