Results 1 to 25 of 28
    Mar 2014
    Midlothian, Texas
    Default Warning regarding Sena batteries
    Sena does not offer battery replacement. I know there are videos on how to replace with a different battery and change out the connectors, but many people do not feel they have the ability to accomplish that. I cannot imagine a manufacturer not offering plug and play battery replacements.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Would you like me to start listing the 100's of products that DO NOT offer "plug and play battery replacement?!?"
    Quote Originally Posted by dbaucum View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jun 2010
    Las Vegas
    I have used Senas since 2014 and have never had a battery issue.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Likewise. Still have the same batteries on my original set. Bought them 2013 ish.
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Ditto... 4th year with same battery and no loss of efficiency. And... when it happens, there are videos that will help me replace a battery (if I want to or want to move on at that point to something newer). Try changing the battery in many cell phones... its a nightmare... or a GPS unit... or.... From the video I viewed the process to replace in the Sena I own is not that hard a task. But... you are right in this... it would be nice if they would make the battery easier to replace in future products.
    Feb 2012
    Spring City,Utah
    If I remember right Apple doesn't offer replacement batteries for some of it's products either. I am on my 4th year with my Senas and they are going strong.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2017
    If you're interested in changing batteries but don't feel comfortable I believe Finless Bob will change them if you send him your communicators, new batteries, and $$ for postage. Seem to recall reading that somewhere on the forum not long ago.
    Mar 2015
    forrest above Reno, Nv
    The aftermarket sells a replacement for the Sena units. The one I purchased had a connector made of soft cheese and I had to solder the wires.
    Lew l
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    Still going strong on the same battery in my Sena 20s since 2014. Finless Bob is a great resource.
    Dec 2015
    Oakley Utah
    Do you need to replace yours? How old is it?
    2014 RTL Platinum
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    I replaced one of my batteries on a 20S following a video and it was not a difficult job at all.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Jan 2010
    usa
    I bought my Sena 20s in 2014 and last year when it was cold out... below 40 degrees the Sena would just work and then shut off. When it was warm there were no problems. I contacted Sena and they said that the battery was old. I bought a new 20s EVO to replace it. It would have been nice to have a "plug and play" option as the unit was still good.. but...... And yes there are lots of manufactures that do not have that option... doesn't make it right. Apple does come to mind, but they are just greedy and hope you will buy something new. (apparently Sena does as well).
    When the going gets tough...Downshift..
    Dec 2015
    Oakley Utah
    Quote Originally Posted by billythekidd View Post
    Corporations aren't people and don't have human attributes.
    2014 RTL Platinum
    IMO, the biggest enemy to Sena battery life, at least on the SMH10, is too frequent charging when there is still plenty of charge in the battery; it gets a signature that shortens its performance life. I charge my SMH10 daily ONLY when on a long tour. All other times I just run it until I get the ,"Low battery, goodbye" warning. Before my most recent tour I just left it on unattended until it shut off by itself and then fully charged it the day before my departure. My SMH10 has been performing well for 4+ years.
    Vermont
    Quote Originally Posted by Arion View Post
    Yes Finless Bob will do that. I asked.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Jul 2011
    Mitchell, Ontario, Canada
    That does not apply to lithium batteries like what are in a Sena. That was a characteristic of Nicad batteries. My Sena SHM10 headset is plugged in and charged almost everytime I use it. Most of the time it stays plugged in until I need it next. I bought the unit in 2012. No sign the battery is going bad yet.
    indpls in
    utah corporations are people and yes they do have feelings and care
    Sena replaced my first SMH10 under warranty after about a half a year of use because the battery life dropped drastically even though the user's manual said it could be recharged and recharged, "many hundreds of times" and I routinely recharged it after every use. Maybe is doesn't develop a signature but since it's long out of warranty I just let it run down until it automatically shuts off.
    The Battery University recommends discharging to only about 50% and then recharge. Once the battery is at 100% don't leave it plugged. Don't put a heavy load on it when it is hot. Heat is a big killer of Lion batteries. Discharge the battery completely every once in awhile, like maybe once a month for a regularly used battery. This lets the internal electronics recalibrate the time to full discharge.
    One reason manufacturers don't make batteries replaceable is the proliferation of counterfeit batteries. An after market, cheap imitation of the original, may actually be dangerous.
    Northern Kalifornia
    I didn't realize Sena used Lithium Ion batteries in their head seats. Just recently there was a house fire near by caused by a Lithium Ion battery left charging on a work bench in the garage. Don't know anymore specifics, however the local TV news interviewed one of the fire officials who strongly cautioned the use and charging of Lithium Ion batteries. Apparently they are blamed for a number of home fires.
    Clinton, MS
    It's almost impossible to buy anything that is battery driven today that does not use some type LIon or LIpo battery. Yes, they can under certain conditions erupt in flame, But, so can your TV, microwave, stove, dishwasher, heater, lawn mover, gas can, etc. That's why we were given common sense........ if we choose to use it. Also why fire extinguishers and insurance were invented.
    Dec 2015
    Oakley Utah
    Deleted
    2014 RTL Platinum
    Northern Kalifornia
    Yep. I recall years back when cell phones in the far east were setting fires and luckily they were not allowed for import to the US. I don't remember the brand or the models but glad someone was on top of it before they were distributed here. Sometime ago I had a Skill brand battery powered drill. I remember it getting hot enough during charging I could smell it and it was warm to the touch. That made the trash in short order. Had to go in a special trash.
    Tell your local fire official "Don't recharge your smart phone then. Strictly a one-time use device..."
    Pete, surely you're not being serious are you? All the fire official was trying to convey is be sensible in using and charging Lion batteries. Don't use the wrong charger, don't leave them plugged in unless the charger is smart enough to not charge when the battery is at 100%, and so on and so forth. Lion batteries are safe until they are mistreated.
    Dec 2015
    Oakley Utah
    No, I was not being serious. Facetious perhaps.
    2014 RTL Platinum
