Results 1 to 11 of 11
    Mar 2018
    Ogden, Kansas
    Angry RT won't start or even turn over
    Yesterday morning it started just fine. Got off of work and it was dead. Tried to jump it. I got power but when I tried to start it, it just clicked one time and was dead. Today I put a a battery charger on it. Went back a few hours later and no difference. I am leaving the charger on all night and try again tomorrow. I am sure there will be no change. It looks really complicated getting the battery out. Is there anything else I need to look at?
    2012 RT , White
    Mar 2015
    forrest above Reno, Nv
    Hi Bob,
    Always helps if we know year and model------ but battery connections have caused all kinds of problems in just about all years and models of s.
    2014 RTS , Circuit Yellow
    May 2017
    Mesa, Arid-Zone-A
    Best guess..... Battery died. They do that and sometimes very suddenly. Good luck..... Jim
    Semper Fi
    Thinks out loud
    Apr 2012
    Quote Originally Posted by Lew L View Post
    Hi Bob,
    Quote Originally Posted by canamjhb View Post
    I'm with these guys. Likely culprit is the battery(how old is the current one?), but I'd check both terminals for tightness for peace of mind.
    Here's some help on getting to your battery > https://www.youtube.com/watch?v=aCsNYNU6eYo
    This is the battery it came with and for the money it can't be beat > Yuasa YTX24HL Factory Activated AGM High Performance Battery
    You can shop around but likely won't find it any cheaper and these folks ship free & fast > https://www.revzilla.com/motorcycle/...ce-agm-battery
    Keep us posted.
    Oh too. I based this post on info in your bio > 2012 Can Am Spyder RT SE5
    Apr 2014
    Beloit Kansas
    when they go, they're gone. They kind of give a couple hints first, like lights brightening
    as revs increase, or doesn't spin over as smoothly as normal. So if it is a battery, fear not,
    it will not be traumatic, and a relative cheap and easy fix
    Jun 2010
    Las Vegas
    The battery on a 13 or newer us very easy to change. The older years are a bit more challenging but look for a YouTube video to help you.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2018
    Ogden, Kansas
    Sorry ya'll. It is a 12 RT Limited. I just now got it to start on my lunch break....once. After that it was totally dead, no light, radio, nothing. I don't know how it did it but it did. Guess I'll investigate a little more. Thanks
    2012 RT , White
    INDIANA, USA
    Default Battery
    Sounds like a new battery might be the trick. The Yuasa oem is a good choice......
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2016
    LI NY
    Sounds like the battery but there is a large fuse on the positive cable you can check
    2010 RTSM5 , stock Stock Silver
    Default Battery....
    My RS 2012 just had the battery go out. Seems you may have picked up a surface charge but that is it and once you use that it's dead. If you tried to jump it and only got a click connections were not good or source was not good. If it is the original battery it is on the high side of life in a spyder. Regardless of if you can get it charged or working you are best getting on with a new one...
    Jul 2019
    Iowa
    Our 2018 RT suddenly wouldn't start after a ride and when turning the key it just had a clicking sound. We found it was a fuse that had went bad. It was the F5 fuse. don't know why it blew but hasn't happened again.
