Results 1 to 14 of 14
    Jul 2019
    Hickory Grove SC
    Default Help my bike is smoking
    Was riding my bike (2012) with14000 miles on it and all of a sudden it started to run ruff and smoke is coming out of the tailpipe!!! Not getting and lights on the dash such as no oil light or over heating PLEASE HELP THIS IS MY FIRST BIKE IVE ONLY PUT SBOUT 3500 miles on it and it was running perfect up until now
    Northern Kalifornia
    Boy, there's not a lot of info to go on here. There's going to be a lot of questions coming your way in an effort to help you out. Are you able to do some of your own work? First question is which spyder do you have.
    Dec 2013
    What he said!
    What colour is the smoke, does it smell of anything like oil or coolant, and is it huffing out as a cylinder fires or is it just pouring out in a steady stream??
    What exactly were you doing when this smoking started? Taking off full bore from a set of traffic lights or coasting slowly along a back road with the breeze in your face & the engine just ticking over? Oh, and it could (well, might, at a stretch... ) help us to know if your 2012 Spyder (RT, RS, RSS, or what?) is a manual SM5 or a semi-auto SE5?
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Default Here's the thing..
    Two possible sources for smoking... coolant and or oil. Not knowing much it is hard to say. Being used and possibly even you knowing less a good place to start would be the air box. Improper oil changes and measurements can cause oil to accumulate there and get to the throttle body fouling the plugs causing rough running and smoking exhaust. Coolant would be more of a gasket problem and harder to deal with and less likely. Of course diesel in the tank can be a cause as well...
    ​2012 RS sm5
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    If it is smoking some fluids have to be going down ,oil ,coolant ,or excessive gas .
    2018 RTL , dark blue
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    Two possible sources for smoking... coolant and or oil. Not knowing much it is hard to say. Being used and possibly even you knowing less a good place to start would be the air box. Improper oil changes and measurements can cause oil to accumulate there and get to the throttle body fouling the plugs causing rough running and smoking exhaust. Coolant would be more of a gasket problem and harder to deal with and less likely. Of course diesel in the tank can be a cause as well...:roflblack:
    That gets my vote.
    The best substitute for brains & knowledge is....................silence.
    Apr 2019
    Florida Swamp
    Can't find anything else that could cause it, do a compression check.
    2019 F3-S , Black & Silver
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Like others have asked, what kind of smoke?
    Is it white like steam? Coolant problem. Check coolant level.
    Is it blue and smell like oil? Oil problem. Check oil level.
    Is it black like soot? Running rich.
    Let us know.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Feb 2019
    Portland, Oregon
    Worse case scenario is a hole in the piston top. Did you fill with Diesel by mistake?
    Those two are not connected.
    OP...where are you? Pls come back and fill us in.
    Aug 2007
    Greeneville, TN
    Smell would be the 1st step in determining the source of the smoke. Oil smells a lot different than coolant. Once you pin down the source. That will help narrow down the cause.
    Most likely, if it is oil and the smoke is constant, is a broken ring as this came on suddenly. But there are other possibilities as well.
    If it is coolant, I'd say a blown head gasket is the source. This can also come on suddenly with an otherwise good running engine. If it is coolant you need to stop running the engine right away. You could easily get water in the crankcase and destroy the engine.
    Let us know what you find.
    Nov 2018
    Waynesboro, PA
    I can tell you that the OP posted in the welcome area that they had a 2012 RSS SM5.
    2012 RTL , Brown
    Jul 2019
    Hickory Grove SC
    Sorry it took so long to get back to you guys for I do really appreciate the feed back��my bike it a Spyder (2012) RSS SM5 and it is running rough and smoking when I release the throttle. It’s a grayish white smoke!
    Mar 2018
    Looks like a head gasket ,does the smoke smell sweet.
    Oct 2014
    Fort Mill, SC
    Have you checked the fluid levels. The fluid that is creating the smoke should be getting low.
    If it is coolant, most likely the head gasket is defective.
    If it is oil, could be defective rings or a small hole in the piston.
    1998 Honda Valkyrie
    US Navy Veteran
