Results 1 to 8 of 8
    Jun 2019
    Montreal, QC
    Default Reverse gear pedal - any existing hacks ?
    Hi,
    After 2-3 weeks with my 900 rally, I must say that switching the reverse gear is a pain, especially if the handle is turned left.
    I could find some upgrades of the pedal, but nothing that would allow me to use my foot to move it back and forth (yes, I'm an old biker so using my left foot to switch gears is normal)
    Anything available on the aftermarket for that ?
    -cheers - Denis
    Active Member Dragracer's Avatar
    Oct 2009
    Lecanto, FL.
    Do a search here in the Ryker forums. Lots of good ideas!
    Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
    2019 900 ACE , Stock Black
    Active Member poli's Avatar
    Feb 2019
    East Texas
    I really don't see why people are having trouble with the shifter. I am 5' 6" and have absolutely no problem what so ever with it using my foot and I use it 3 to 4 times every time I go riding.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Jul 2019
    CO
    Jun 2019
    Montreal, QC
    Thanks - found the May discussion where the reverse gear problem is discussed.
    FYI: I'm 6'3" and can't use my foot the way the handle is set.
    I'll consider the hack to extend the handle
    May 2019
    Washington
    i find not using my toe and using the bottom of my foot works perfect everytime.
    Feb 2019
    England
    Hi Jerryturner I did the same but cut end off and drilled a hole through pedal arm and ordered a rubber to match the BRP one , then passed a dome headed bolt through the rubber with a nut on engine side Now it matches the other rubber and looks much more professional Regards Nico 75
    Dec 2018
    Peculiar, Missouri
    Have two shifters on the way for my two 600's. Looking forward to getting them on. Mike
