Results 1 to 18 of 18
    Active Member mmmdowning's Avatar
    Dec 2017
    Virginia
    Default Limp Mode, 2016 spyder rts se6
    Over the weekend I added the Slingmods LED headlights and fog lights. The bike started fine, moved it to the driveway and parked it. This morning when starting it, it ran ruff. The idle was at 700 and when I backed out of the drive and then going up to about 55mph the screen went orange and went to limp mode. So turned around and went back to the house and parked it. Could the current change on the LED's have caused this? When I get home this evening I'll check more into it, but just confused.
    2020 RT Limited SE6
    2016 RT-S , white
    I have added Dozens of LED's to my 14 RT ( including headlights ) ….. this hasn't caused Any issues …… your issue is something else …. more info needed …. Mike
    Default Ouch....!!
    You need to get the codes or warning signals to get a better Idea of what is going on. LED's can cause problems if not properly install or not compatible to the system. One quick check would be to back track and see if the problem goes away. ...
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    I agree with Mike, pretty unlikely that the lights themselves caused the problem but you may have done something installing them that is upsetting the nanny.
    If you are still getting errors tonight you need to pull codes. With the key on push the Mode, Set and Turn Signal buttons all at the same time. If you have an active code it will be on the screen.
    Did you remove the front trunk when you installed the fog lights? If you did I bet you didn’t reconnect something properly.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2014
    Mint Hill, NC
    SlingMods is Tricled's biggest distributor. I installed Tricled LED headlights and fog lights Friday and bike runs like its usual top self. Since the lights are plug and play I agree with Mike and Ann it would be extremely unusual for the lights to cause the bike to go into limp mode. Are you certain you got the polarity correct on all four lights? It would be obvious is you didn't because a light with reversed polarity will not light. Did you pull the frunk to get that left fog light installed? If so, are you certain you got all the electrical connections reconnected when you reattached the frunk? If you missed one it might be the one that completes the circuit to the ambient air temperature and pressure sensor. As Ann said, you should pull any codes you can. If you get a P222B and/or P011C the system they are related to the ambient air temperature and pressure sensor. BTDT, got the T-shirt.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Cognac 2014 RT-S
    But it takes an Army Aviation spotter plane to call it in.
    US Army Aviation 1959-1962
    Dec 2017
    Virginia
    I was able to pull codes, they are:
    P1171
    P0130
    P0171
    2020 RT Limited SE6
    2016 RT-S , white
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by Baron14y View Post
    Cognac 2014 RT-S
    Not the Devil Dogs, we have our own aircraft and aerial observers!
    Cognac 2014 RT-S
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by mmmdowning View Post
    P1171
    P0130
    P0171
    Doesn't sound at all related to the lights.
    P1171 = ECM = Fuel correction reached the maximum limit, additive = Any reason which will cause a lean condition at idle, ex: fuel pressure too low, clogged fuel injector, defective fuel injector (sticking), large quantity of ethanol fuel mixed in the tank.
    P0130 = ECM = HO2S signal not plausible = Defective O2 sensor, damaged circuit wires,damaged connector...Canister purge circuit defective, canister purge valve installed in wrong flow direction, Fuel pressure too high or too low.
    P0171 = ECM = Fuel correction reached the maximum limit, multiplicative = same causes as for P1171.
    Sounds like a job for a technician with B.U.D.S.
    Cognac 2014 RT-S
    Jun 2019
    Upstate New York
    P1171
    P0130
    P0171
    These codes deal with the O2 sensor (P0130) and a lean fuel condition, according to the F3 Service Manual. They could be the same for the RT, I would think.
    Dec 2017
    Virginia
    Thank you, to the shop it goes again. So in a month and a half i've had the guage cluster go bad and the oil cooling tank/radiator go bad. Replaced by best warranty, thankfully? I've put just over 14000 miles in a 1.5 yrs. Bought new old stock. I hope the down time becomes less. I truely enjoy riding the spyder. But with a possible 3rd in the short time I may go back to Honda goldwing. I drive daily 147 miles on interstate 95 and ride the hot lanes. Trying to save miles being put on my Tundra.
    2020 RT Limited SE6
    2016 RT-S , white
    Dec 2013
    If you pulled the frunk off when you were installing the lights, or even if you were only just poking & playing around under there in amongst all the other bits of hose & wire under the tupperware, I reckon there's a good chance that you've simply disturbed or disconnected something to do with the ECM or the O2 sensor. And if that's the case, why not have a sticky under the tupperware & see if you can connect whatever back up or re-seat the plug, unkink the hose?! You'll feel a bit silly if you take it back in to the dealer where it sits for a couple of weeks before they get a chance to look at it & then the tech fixes it in 10 seconds by simply re-connecting the O2 sensor or some other hose or wire, won't you??
    So I'd be having a go myself - have a look in the area where you were doing things - check the ECM connections & the O2 sensor to make sure they've got a good connection, look for anything unplugged & re-plug it if necessary, check to see if there's any pinched hoses or broken wires - it really only looks complex cos of all the wires & bits going everywhere, but you don't necessarily need to know EVERYTHING about it all just to look for a kinked hose or an unplugged wiring connector, do you?!? Go on, have a go! If you fitted the lights, then surely you can do this!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    May 2017
    Mesa, Arid-Zone-A
    I agree with Peter. A sudden and unexpected problem after working on a vehicle is almost always a result of "What was the last think I did". Walk yourself backward and look at everything you touched. And look at everything you may have unintentionally come in contact with. I bet that it is something you inadvertently disturbed rather than the lights. Good luck..... Jim
    Semper Fi
    Dec 2017
    Virginia
    I double checked the connections, wiring, vacuum lines. All looks good. I didn't remove the frunk to change the fog lights. S we will see what the shop says is wrong and another two weeks down the drain. After this I feel I'm going to a Honda Gold Wing '18 or '19.
    2020 RT Limited SE6
    2016 RT-S , white
    Jul 2014
    Mint Hill, NC
    Did you lift the Spyder at all during your work? Have you checked the oxygen sensor and its connector wire?
    Cognac 2014 RT-S
    Dec 2017
    Virginia
    The dealer called and said the #1 plug fouled and the fix is replacing all 3 plugs at 14,800 miles for $430. I asked if something failed to cause the fouling and he asked me if I drive high speeds. Really?? My frustration is high now. I'm calling it quits on the Spyder. Going to a new Goldwing. I have truly enjoyed the things I have learned here and the great folks. I should be able to bring the bike home today and trading in tomorrow.
    2020 RT Limited SE6
    2016 RT-S , white
    May 2019
    New Mexico
    Since it's only one plug out of the three, it was the plug itself that went bad, not the bike. Those fault codes simply saved you from burning out your catalytic converter.
    Dec 2017
    Virginia
    They added that the injector failed, so they have ordered and another week before I can do anything.
    2020 RT Limited SE6
    2016 RT-S , white
