Results 1 to 15 of 15
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Default Adjustment for OEM Driver's backrest
    I put the OEM driver's backrest in yesterday, and rode into work this morning. Felt like I was being pushed way forward. Is there any adjustment for that thing? If not, it's coming off and getting sold.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Bryant, Arkansas
    Should be a screw under the flap on the bottom of the back rest that allows you to adjust the forward and backward setting.
    Cruzr Joe
    Here's the adjustment screw. It takes a 5 mm Allen wrench to adjust and the thread is coarse so a little tweaking goes a long way.
    Lancaster,SC
    I feel the same way with mine. I'm still adjusting to see where I want to keep it at.
    Lawdog, retired police but still doing the job for second retirement.
    2018 Spyder RT Limited
    Asphalt grey, chrome, back rest, arm rests, cup holders from canamspyderaccessories.com
    Mar 2019
    Central SC
    Great, thanks for the help. I'll be trying that out today and see how it goes.
    2014 RT-S , Orange
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Just looked. Nothing like that under mine.
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by Baron14y View Post
    Then you have the non-adjustable version. There is an accessory kit you can buy to make it adjustable, but it's pretty pricey. Last time I checked it was close to $100.
    Thanks, Boilermaker! I thought most folks were aware that when BRP introduced a drivers backrest for the RT it was not adjustable and then, I don't know when, introduced an adjustable version at which time or shortly thereafter they introduced a kit to convert a nonadjustable backrest to an adjustable one. Go to this link and prowl around,https://can-am.brp.com/on-road/shop/...sts-racks.html.
    Aug 2018
    north wis
    Take it back and ask for a current model? Got mine 2 wks ago and is adjustable!
    May 2017
    Mesa, Arid-Zone-A
    I had the exact same problem. Pushed me too far forward. I found out I had the standard backrest bracket and it was not adjustable. The adjustable bracket solves the problem. I believe the cost was $80.00. Readily available and easy to install..... Jim
    Semper Fi
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    I put the adjustable kit on mine and still was not enough so took the adjustment screw out to get what I wanted.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Nov 2018
    Claremore, Ok.
    I went to the link, no response to add to cart. ????
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Worked for me. Call'em at 877-412-7467.
    Mar 2019
    Central SC
    That's what I found this weekend, no adjustment in mine. Oh well, it came with the Tryke, so I'm not that attached to it. Guess it goes.
    2014 RT-S , Orange
    Quote Originally Posted by Wahrsuul View Post
    The adjustable kit for the OEM seat is $80 and your not adjustable backrest will then fit on your bike. Don't know if Cheap Cycle Parts can give a better deal, doubt it because it's an accessory and not a regular part. You could try a Utopia backrest for $249 or try the adjustable kit for your backrest and have the option of removing the adjustability bolt if necessary. My wife gave me the adjustable backrest as a birthday present and I am not at all embarrassed to admit that it was my own stubbornness that kept me from getting one. On real long rides it does reduce fatigue for me. Were I in your boots,since I already had the backrest I'd consider $80 a reasonable gamble. At worst case you could gamble and if it doesn't work, try a Utopia and sell off the nonadjustable backrest and the adjustable backrest support.
