Air Compressor ?
I was thinking about adjusting the air pressure in my 2018 RT. For the rear suspension.
Why according to the owner's manual should I use the gas station compressor? Wont a shop compressor work?
Do they are too much pressure?
No, it's just a suggestion in case you're on the road. A gas station compressor may have a built in gauge in the nozzle, or that you can dial in the desired pressure, so that you can inflate the air bag per the table in your manual. If you have your own compressor and a gauge you're good to go. And thank you for reading the manual.
Doug
”Freedom is not a loophole”
A bicycle pump or 12V portable pump will work fine. A small bicycle pump will fit in a compartment without taking up much room and it is wireless.
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
Why not use a shock pump. Much safer if you dont want to use the bike compressor
It's just an r t not a r t l no compressor
