Results 1 to 5 of 5
    Jul 2018
    Saskatchewan
    Default Gauge switching ?
    How hard would it be to have a switch that would run either round gauges or dash display? What wire would need to be switched? 2015 RT SE
    Bryant, Arkansas
    simply unplug both the round gauges and the dash display will be operative.
    Cruzr Joe
    Default Not sure...
    Not sure but should be easy enough to check out. Simply unplug one wire to the gauges and see if the digital appear on the screen and then put a switch on those. I do not have a wiring diagram so not familiar with the coding. Just remember they both have to be disconnected to have the digital appear on screen.
    ​2012 RS sm5
    Nov 2018
    Claremore, Ok.
    A DPDT switch should do the trick. Bring hot+ side of each gauge to center terminals of the switch, then another set of wires from the other terminals of switch back the original terminals on each gauge. Then if you later decide to just use the digital gauges you've got a DTDT switch for other farkles.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jul 2019
    UK
    Yes, a single pole switch used to make/break the blue wire at the fuel gauge should do it. This wire connects the fuel gauge to the cluster. For info, the other wires at the gauge are: Power to the gauge, power to the illumination and ground.
