P010 Check Engine Light Fault Code
Hello All.
I’m relatively new so here goes.
I have just replaced my Spark Plugs with Iridium Plugs and High Flow leads.
I have also replaced the OEM air box and filter with a JT’s Spyder Store Filter Kit.
I’m now seeing the check engine light come on.
I have checked for the fault code and it comes up showing P010.
Can anyone throw some light on the for me.
Cheers
Dougy
Are you sure that’s the code? You need one more digit.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Bummer.....
If it should be P0100....Mass or volume air flow circuit malfunction re check the new air system from JT and make sure all hoses and sensors are connected....
2012 RS sm5
I agree with Ann. Not enough digits. Please post the full fault code and we will help you out.
2018 F3 LIMITED
AS always check the last place you did some work.
Hey Peeps sorry for the late reply.
I have been in touch with. Tech here in Adelaide. He also says that there is a missing number at the end.
They have told me to ring my ride in so that they can plug into a PC.
They also said it’s due to the JT air filter I fitted. My ECU may need flashing.
I have also run it on idle for 30 mins so the ECU could re learn but this didn’t work.
My ride runs perfectly smooth. Has a nice bark note in the exhaust.
I have emailed JT but he wasn’t sure why the Check engine light come on.
The new Iridium plugs and hi flow leads work a treat.
