Results 1 to 6 of 6
    Aug 2018
    Adelaide South Australia
    Default P010 Check Engine Light Fault Code
    Hello All.
    I’m relatively new so here goes.
    I have just replaced my Spark Plugs with Iridium Plugs and High Flow leads.
    I have also replaced the OEM air box and filter with a JT’s Spyder Store Filter Kit.
    I’m now seeing the check engine light come on.
    I have checked for the fault code and it comes up showing P010.
    Can anyone throw some light on the for me.
    Cheers
    Dougy
    Jun 2010
    Las Vegas
    Are you sure that’s the code? You need one more digit.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Bummer.....
    If it should be P0100....Mass or volume air flow circuit malfunction re check the new air system from JT and make sure all hoses and sensors are connected....
    Jul 2011
    Mitchell, Ontario, Canada
    I agree with Ann. Not enough digits. Please post the full fault code and we will help you out.
    Mar 2018
    Ontario ,way up north
    AS always check the last place you did some work.
    2018 RTL , dark blue
    Aug 2018
    Hey Peeps sorry for the late reply.
    I have been in touch with. Tech here in Adelaide. He also says that there is a missing number at the end.
    They have told me to ring my ride in so that they can plug into a PC.
    They also said it’s due to the JT air filter I fitted. My ECU may need flashing.
    I have also run it on idle for 30 mins so the ECU could re learn but this didn’t work.
    My ride runs perfectly smooth. Has a nice bark note in the exhaust.
    I have emailed JT but he wasn’t sure why the Check engine light come on.
    The new Iridium plugs and hi flow leads work a treat.
