So, in a moment of clumsiness, I managed to hook my mirror with my messenger bag when opening my frunk and I broke the mount where the mirror attaches to the bike. It was only the top mount, so the mirror is still hanging on with the other two mounts on the bottom, but now it is unstable and bounces a lot when I ride. It isn't the mirror itself that is broken, but where the metal pin attaches to the plastic behind the dash. Where the pin used to attach there is now a hole. I am guessing the plastic piece broke and fell inside somewhere.
Has anyone else ever had this happen, and if so, is there an easy fix? I have looked online at some parts places and it seems that there is a possibility that I might have to buy the entire console support, but it would require me to fully disassemble the top of the bike to get it out. The part itself is actually cheaper than I expected, but it does look like a hefty installation. I am attaching a picture of the breakout drawing of the console area, with my notes. I am hoping it is just part 507 that I need and not part 405. I will draw a circle where I busted it. The pin that is not attached now is the one labeled 458. I am pretty certain that it hooks only to part 507.
Actually ya I have broken one first time I tried removing mirrors. It's only 3 little screws, the replacement will be just as flimsy so caution there. https://www.cheapcycleparts.com/oemp...ies-windshield part 507 should be it. As far as what broke & fell inside, will probably just be lost the the "Void" good luck
I too have broken this piece (left side) on my ST. I had both sides removed last month to do some service work.
I removed to upper tupperware to gain access to the plate 507. Its time consuming but not too difficult.
Use the parts diagram to find all the tupperware screws to get the upper tupperware panel off.
In my case the turn signal wire are routed thru the panel. Make sure the spring clips are properly mounted.
I had one spring clip push out of its mounting point upon reassembly.
Good Luck,
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
I have had to replace both sides at least once each. That plastic bracket is the weak point of the mirror attachment system. While the two lowest pins snap into their respective holes with the help of two metal “clips”, the top slot is all plastic and consists of only 3 small tabs. Doesn’t take much to snap one off.
Good Luck,
Thx for that, FYI mine was replace by dealer not DIY so I may be wrong about just 3 screws srz & mine is a '13 maybe some differences there.
I've had both mirrors become "disconnected" at the lower mount point, due to some rough roads.
So far nothing seems broken, and the mirrors usually pop back on pretty easily, though I did have trouble with left side recently and went to the dealer and the tech spent about 10 minutes getting it back on.
Is there NO alternative or replacement available, e.g. Magic Mirrors, since it may take some time to repair all the NJ potholes?
I had to replace the rhs mount on my STS. I keep mine in the barn at my folk’s place for now while I’m trying to sell it. Apparently the we’re trying to put their pontoon boat in there and clipped the mirror, knocking it off. When trying to get it back on I saw the tabs in the top hole where that pegs goes were broken off. I had the most free a new plate , fortunately it cost just under 18 bucks for a new plate.
Here is info about the ST mirrors that I have collected over time. See the italics near the bottom of the post.
Mirror Removal on ST
I took the left mirror off yesterday. What a pain in the butt. It really isn't that bad except the service manual instructions are just plain wrong.
The first step of removing the 2 allen head screws in the deflector. Remove deflector.
Remove the bottom plastic cover.
Remove the torx screw holding the top plastic cover and remove the cover.
Next service manual instructions is to disconnect the signal light wire. That is wrong that is 2 steps too early and can't be done yet.
The service manual says to push the mirror rearward well that's wrong. You need to lift the outside of the mirror to release the bottom 2 pins from the spring loaded snaps.
When the bottom 2 pins are free lift the whole mirror assembly up to release the top pin.
After mirror assembly is loose disconnect the signal light wire.
Remove the base mounting plate by removing the 4 allen head screws.
Yup the manual is way wrong.
After you remove the deflector, the bottom and top covers... give the mirror a sharp rap straight up. Hit it from the bottom about 2-3 inches out to get some leverage. It will 'bust' loose the two bottom pins from the wire spring type sockets. It will indeed sound like its broken. Then nudge it up a bit more to release the top pin.
When you replace it,
1. slide the top down into the 'V' shaped slot
2. then a firm press in on the bottom will snap the two bottom pins into the spring sockets.
I put anti-seize on the two spring sockets (a tip from Spyderpops - Harvey) which helps them slide in and seems to make removal a bit easier. Did this on the RT mirrors and it made their removal much smoother.
Hope this helps
David C
2016 F3T
Rear IPS Pack Rack
Grandson broke the mirror mount when playing around the Spyder. I was about to remove all the tupperware on the left side until I read the above posts. Thanks all for the posts as they saved me a lot of time. I was also pleasantly surprised the item was in stock in Sydney and the cost was not exorbitant, $42.22 Aus.
Another good example of the value of this forum!
Glad to see you got it fixed so cheap. These forums are invaluable for this.
We lost Cheapcycleparts recently, so not sure where I am going to go to get parts now. I also see you have the exact same year/model/color as me. This was my favorite color scheme of all of the Spyders, I hope they bring it back with some of the newer ones when I decide to upgrade to a new model.
AlphaJoe
2014 ST-S - Congnac
LidLock helmet locks
LAmonster Ram mount with X-Grip
The bolts for the RT/ST also fit the F3 for any year after 2013.
I repaired the #507 plate on the F3 by epoxying the LaMonster bolt in place of the broken bit of the 507 plate.
David C
2016 F3T
Rear IPS Pack Rack
