Results 1 to 15 of 15
Thread: Battery life?
    Jun 2019
    Kansas
    Default Battery life?
    My wife and I are new to this fun game. We have a '12 RT-L and a '13 RT-S. I asked the dealer to replace the batteries, but they said they checked out in good shape. I was frankly surprised. How long have batteries lasted in your experience?
    Thanks for your time and expertise.
    Last edited by ARtraveler; 07-23-2019 at 01:11 PM. Reason: changed had to have per OP.
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Heat kills batteries faster than the cold. Hence, living in a very HOT climate mine are replaced every three years without question.
    Very Active Member jnt's Avatar
    May 2008
    Minneapolis
    When we sold our original RS/GS this Spring, it had the original battery. From 08. Not bad
    08 RS/SM5 (Hers) (sold)
    15 RT-S (Mine)
    2015 RT-S , Metallic Black
    Sep 2013
    Johnson, Vermont
    MY 2012 RS still has the original battery....no issues yet.
    Feb 2013
    Edinburg, TX
    I've had mine four years this week and the battery is still quite strong. I occasionally forget to turn the key off, but it charges right back up OK. Very hot climate here, too, but I'm parked in carport shade most of the time. But as I've just rolled up 72,000 miles, it's not parked in the shade all the time!
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Default Lets see....
    From my time here and seeing the many posts.....it seem 3 to 7 years. Mine on the RS 2012 made it 6 year some that were not set up correctly came in under the 3 years. There are a lot of contributing factors.... electronic add ons, charging and discharging, weather amount of ryding time etc. I, with the help of the kids, worked my battery hard and it did well. A well set up YUASA is still the best IMO.....
    ​2012 RS sm5
    Active Member Raknid's Avatar
    Central NJ
    We just put the third in our 2012RT. Original was replaced in 2017 so the second lasted only a little over two years - which is disappointing. Hopefully this one will last longer.
    2012 RT-SE5
    Jul 2019
    Iowa City, Iowa
    I just bought a 2015 F3 with only 1600 miles on it.
    It was actually purchased in 2017. So it sat in a dealers show room for two years and then sat in his garage a good share of the time he owned it.
    The pervious owner told me that he replaced the battery just before I bought it and showed me the old one setting in the garage.
    He only put 1600 miles on the machine over a two year period. I don't know if he put it on a trickle charger while parked.
    That being said, I'm concerned about some other things. Should I be changing the fluids as well?
    And what else should I consider?
    I change them out every three years whether they need it or not.
    There is a lot of draw on the battery from many sources. When they die they usually do not give a lot of warning. I don't want to be stranded far away from home or dealers.
    Oct 2015
    Lynden, WA
    2013 STS with the original Yuasa battery.
    I have a replacement on the shelf just in case.
    Will replace the battery before I travel long distance this fall.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jan 2019
    North Carolina
    After reading tons of threads on this subject, I'm seeing an average of 5 years.
    More importantly, I am reading that's it's best to go back with the same battery!
    May 2009
    Connecticut
    Quote Originally Posted by Jackhartjr View Post
    Very Good reading ! I think that about sums it up.
    Sea Doo GTI-SE 90 Jet Ski!!
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Get yourself a load tester, takes the waste and guesswork out of it.
    https://www.ebay.com/itm/Car-Truck-V...-/312525479678
    2017 F3S Daytona , Circuit Yellow Metalic
    Jul 2019
    ND
    I just purchased a 2017 F3. The dealer said I should get a lifetime battery replacement agreement. He said the batteries only last about a year because of all the electronics. I don't really buy that. $160 for the agreement. Any thougts?
    Apr 2012
    Note to Dealer
    Go pound sand!
