Results 1 to 22 of 22
    Jan 2019
    Hunter Valley NSW Australia
    Default Tow Ball removal - Genuine BRP tow Hitch
    Hi guys,
    Trying to replace the 1 7/8" towball on BRP Genuine tow hitch and not having much luck. But a breaker bar on the ring spanner and started to drag the RTL across the floor.
    1. Is the nut welded to the tow hitch?
    2. Or, is it a bolt that screws up into the tow ball, requiring me to latch onto the tow ball with something to remove?
    3. Or is it just firken tight?
    2017 RTL , White
    Sep 2014
    USA
    Quote Originally Posted by askitee View Post
    Hi guys,
    1. Is the nut welded to the tow hitch? NO
    2. Or, is it a bolt that screws up into the tow ball, requiring me to latch onto the tow ball with something to remove? YES
    3. Or is it just firken tight? That too
    Commments next to questions
    Got a good impact gun?
    Or take it to a hitch shop they will get it off
    Florida Swamp
    Heat the nut and it will come off. You don't need a torch, you can heat it with a little propane unit.
    If you have an impact, heat it and then use the impact on it.
    2019 F3-S , Black & Silver
    SoFlo
    Pretty sure the book spec torque is super tight. Guessing you will need a 3/4” drive Breaker Bar and socket to get it loose.
    Curious, are you removing it to install a basket rack?
    Jul 2010
    Las Vegas, NV
    Most auto parts stores have 1/2 “ drive sets to borrow. Big breaker bar. Wrench on the base.
    Joe Meyer
    Jan 2019
    Hi PMK, in Australia the tow ball standard is 50mm, and the 1 7/8" rattles like crazy inside the 622 Trailer 50mm coupling.
    2017 RTL , White
    Florida Swamp
    Hitch ball reducers....... it is a sleeve, like a bushing to make the smaller bolts fit the larger holes.
    Mar 2013
    The is a nut on the coupler that you can tighten that will reduce the rattle. That's what I did on my 622 trailer.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    SoFlo
    Quote Originally Posted by PW2013STL View Post
    Not sure the adjuster can compensate for 3/32” difference in ball size.
    1 7/8” = 1.875” = 47.625mm
    1.968” = 50mm
    2.00” = 50.8mm
    Seems the truth lies in what hitch size is on the trailer. Original poster says the Australian RT622 calls for a 50mm trailer ball, so probably best to get it swapped out.
    Mar 2013
    1.968” = 50mm
    2.00” = 50.8mm
    You maybe correct, but it cost nothing to try the adjustment first. I know mine rattled a lot before I adjusted it. Now it doesn't rattle at all.
    Active Member NorthAlabamaSpyder's Avatar
    Jun 2017
    North Alabama
    I had to remove the ball to put a Bushtec hitch pin on. had my neighbor put a crescent wrench on the ball so it wouldn't spin and I used a 1/2" breaker bar with socket. Or course the itch was on the Spyder. Wasn't to bad but that baby was on there.
    2019 F3-T and some extra stuff
    Jan 2019
    Hi all, thanks for the other options, handy to know.
    While I did have the option to adjust it, for $6.00 for a towball I'd prefer to have everything the same spec as everything else rather than having to adjust the coupling each time I used it on another vehicle.
    Had another crack at this time and was able to remove the OEM towball, had no idea the US/Cananda towballs have a bolt that screws into the ball (ours have a stud). Need to drill out the hole from its original size to take the stud of the AU 50mm
    2017 RTL , White
    Both styles are sold here.
    Bryant, Arkansas
    Quote Originally Posted by NorthAlabamaSpyder View Post
    SoFlo
    Yes, oem Spyder hitch uses the bolt style ball. Pretty obvious, but when going to the stud style ball, ensure the hitch structure is adequate thickness, or add washers to prevent bottoming the nut on the threads before getting full tension on the stud threads.
    Over the years, it has amazed me how many hitch balls were loose on the hitch, but never fell off because the threads had bottomed out. Not Spyders but cars and trucks pulling bigger trailers.
    Jan 2018
    mondovi wi
    you donot need to change out your 1 7/8 ball get down and look under your trailer hitch where the ball fits into. their will be a bolt and nut, usyaky the nut is a 3/4 size this type of hitch can be adjusted tighter or looser.. when we bought our tlr i needed to loosen the nut to get the hitch over the ball.. it was rather funny because the sales person did not even know about the hitch lock adjustment on the under side
    Sep 2018
    Missouri
    I am looking at the BRP hitch along with a J&J flag mount. Does the BRP hitch have a 3/4” mounting hole?
    Jan 2019
    Its been a while since I posted this but i seem to recall the hole for the towball stud was around 3/4" (19mm).
    For those still suggesting options, it's simpler to fit the correct towball than have to adjust the tow head each time i switch vehicles. Thanks for the information on other options though
    2017 RTL , White
    Its been a while since I posted this but i seem to recall the hole for the towball stud was aroubd 3/4" (19mm).
    And if you happen to have a prang or get sprung by the Constabulary here in Aust with your 50mm trailer hitch coupled up to a 1&7/8" ball, it's gonna cost you!! Possibly a LOT!
    Far simpler & potentially a whole lot cheaper to fit the correct sized ball - no matter how tight the adjuster might make it seem to fit, the numbers hafta match!
    Jan 2019
    Nsw has no specification on ball size however it refers to AS4177-2 which recommends that 50mm towballs be used. The 1 7/8" ball is still ok so long as it has a weight rating stamped somewhere that is in synch with the weight being towed
    2017 RTL , White
    Dec 2009
    West Oz
    A 1 7/8" ball is not ok if hitch is 50mm. There's a very high chance it will detach when traversing lumps & bumps in the road. I wouldn't like a 500kg trailer (and that's probly illegal too) swinging on the chains behind me.
    Sep 2018
    Missouri
    It was 3/4”. Installed my hitch and flag mount
Tags for this Thread
