Results 1 to 5 of 5
    Apr 2015
    tampa
    Default RT nose distance?
    How close to the ground is the front of spyder rt-s nose. Asking for transportation info.
    I may have to get planks? Just checking.. Thnx.
    Dec 2015
    Oakley Utah
    Why don't you measure it?
    2014 RTL Platinum
    Default Depends...
    Depends on if any work was done to the front end. Swaybar, cargo carried, shock relocators, spring stiffners or shocks many can change the front end hight. I would measure it if possible to be sure what is your height. My RS has many mods and would not be a good reference to help you....
    ​2012 RS sm5
    Jul 2014
    Mint Hill, NC
    Are you measuring to bring a new RT home? Do you have a bump skid? It will make a difference.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    3.5 in
    2018 RTL , dark blue
