Results 1 to 3 of 3
    Active Member Pallidus Aranea's Avatar
    May 2018
    Eastern Shore of MD
    Default 2018 CanAm Spyder RT Limited (Pearl White / Chrome)
    2018 CanAm Spyder RT Limited For Sale
    EDITED POST 8/22/19
    Spyder Lovers, Sorry that I have not edited this sooner. I had too many plates spinning at one time for a while.
    I have enjoyed my Spyder immensely but it is time for is us to part ways. I have severe neck damage and riding in general is no longer a great idea. So .... it time to let her go. As stated in the title it is an 2018 RT Limited, Pearl White / Chrome trim package. The only modification / addition to the Spyder is the addition of the BRP backrest. It has had all maintenance completed and garage kept. Battery tender / full cover included. I will consider any serious inquiries and offers.
    Please private message me if you need to. I will answer all questions.
    Dave
    Here are the details that you are all too familiar with.
    Pearl White with Chrome Accents
    ENGINE
    Rotax® 1330 ACE™ in-line 3 cylinders, liquid cooled with electronic fuel injection and
    electronic throttle control
    Bore & stroke 3.31 x 3.14 in. (84 x 80 mm)
    Power 115 hp (85.8 kW) @ 7250 RPM
    Torque 96 lb-ft. (130.1 Nm) @ 5000 RPM
    CHASSIS
    Front suspension Double A-arms with anti-roll bar
    Front shocks type /Travel SACHS† Big-Bore shocks / 6.9 in. (174 mm)
    Rear suspension Swing arm
    Rear shock type / Travel SACHS Shock with self-leveling airpreload adjustment / 6 in. (152 mm)
    Front brakes calipers 270 mm discs with Brembo† 4-piston fixed
    Rear brake 270 mm disc, 1-piston floating caliper with integrated parking brake
    Front tires MC165/55R15 55H
    Rear tire MC225/50R15 76H
    Aluminum front rims Chrome, 12-spoke , 15 x 5 in. (381 x 127 mm)
    Aluminum rear rim Deep black, 15 x 7 in. (381 mm x 178 mm)
    DIMENSIONS
    L x W x H 105 x 61.9 x 59.4 in.
    Wheelbase 67.5 in. (1,714 mm)
    Seat height 30.4 in. (772 mm)
    Ground clearance 4.5 in. (115 mm)
    Dry weight 1,012 lb (459 kg)
    Storage capacity 41 gal (155 L)
    Maximum vehicle load 494 lb (224 kg)
    Fuel capacity 6.9 gal (26 L)
    Reserve 1 gal (3.8 L) approx.
    Fuel type Premium unleaded
    FEATURES
    Instrumentation
    Large panoramic 7.8” wide LCD color display with BRP Connect™: allowing the integration of vehicle-optimized smartphone apps such as media, navigation and many others controlled through the handlebars. Gauge functions include: speedometer, tachometer, odometer, trip & hour meters, fuel consumption avg, gear position, ECO mode smart assist, temperature, engine lights, electronic fuel gauge, clock, and more.
    Running lights 2 halogen headlamps (55-W)
    Fog Lamps / Accent Lighting Included (RT)
    Windshield Touring - Electric adjustment
    Wind deflectors Standard
    Cruise control Electronic
    Seat Ultra comfortable with driver backrest and lumbar support and passenger backrest
    Rider heated grips Standard
    Audio system BRP Audio Premium 6-speaker sound system with AM/FM, USB, Bluetooth† and 1/8” (3.5mm) audio inputs
    Towing capacity 400 lb (182 kg)
    SAFETY & SECURITY
    SCS Stability Control System
    TCS Traction Control System
    ABS Anti-lock Braking System
    DPS™ Dynamic Power Steering
    Anti-theft system Digitally Encoded Security System (D.E.S.S.™)
    Current Mileage: 7587
    Current Location: Preston, Maryland
    Asking $28K - Negotiable
    INCLUDED IN SALE:
    - CanAm Drivers Backrest
    - Guardian Full Cover
    - Schumacher Battery Tender
    - 2 HJC IS Max 2 Helmets (White- Sized XL)
    - 2 Sena 20S units – installed in helmets
    - 2 Rocket Joe armored / vented jackets (sized XL)
    ****Reasonable Offers considered****
    ****No Trades Considered****
    Dave
    "Pallidus Aranea"
    (Pale Spider)
    • 2018 CamAm Spyder RT Limited - Pearl White / Chrome
    • 2008 H/D VROD 105th Anniversary Edition (665 of 1200) - Retired
    • 1987 Honda CRB600F - "Hurricane" - Retired
    "Any intelligent fool can make things bigger and more complex… It takes a touch of genius – and a lot of courage to move in the opposite direction." - Albert Einstein
    2018 RT Limited , Pearl White
    Feb 2012
    Spring City,Utah
    posting a price and some pictures would probably help your cause.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2015
    Oakley Utah
    Mileage? Warranty?
    2014 RTL Platinum
