Results 1 to 25 of 26
    Mar 2015
    West Palm Beach, FL
    Default Help! Spyder not starting
    My F3S was left outside overnight and it rained. The next day I dried it off and went to start it and something "popped" and now there is no power to anything.
    I did check all the fuses and none are blown that I can tell.
    I'm at a loss. I would really like to fix this myself as the local dealer is expensive (I'm being nice)
    Worst case I would need to get it to the dealership. How can I get it on a trailer if I can't get it in neutral? SE transmission.
    Ron
    2015 F3-S , Can-Am Red (Orange)
    Florida Swamp
    No sure about that year model............ look in the manual. There should be a way to shift it into neutral manually with a wrench.
    2019 F3-S , Black & Silver
    Jul 2011
    Mitchell, Ontario, Canada
    Take a look at your battery. Sound like a loose cable connection to it. Make sure they are clean and tight.
    PS Your Spyder will roll in gear. Without power you cannot release the parking brake.
    Feb 2019
    Portland, Oregon
    I'm thinking that maybe water got into the switches. Try blow drying and some WD-40. The WD stands for water disbursement.
    Mar 2015
    West Palm Beach, FL
    I checked the battery and it is fine.
    I'll try the WD40 next. When you say switches, you are talking about
    May 2017
    Mesa, Arid-Zone-A
    I would clean out ALL your electrical switches, anything exposed to the rain. But not use WD40. While it may provide temporary relief, it leaves a residue that will attract dust and dirt which will, sooner or later, result in failed switches. Instead, use compressed air that come in a can. Commonly used for computer keyboards. If you must use a lubricant, use silicone spray as it will not attract as much gunk as WD40 does. I think I will probably be criticized by WD40 lovers. There are lots of good uses for it. Just not in electrical switches that are exposed to the elements, and I am only speaking of my own personal experience. Good luck..... Jim
    Semper Fi
    washington state
    try to jump the battery
    Apr 2012
    Arizona
    There is a spray QD Electronic Spray
    that cleans the electric componets and dries super fast.
    Feb 2019
    Portland, Oregon
    Canamjhb is correct about WD-40. I was just doing the "any port in storm" thing, figuring you had some on hand.
    Another thing to try is Contact Cleaner, but I was reluctant to suggest it as it might harm plastic.
    Jul 2011
    I'm not sure which switch would be bad, in this case, to spray something into but a few thoughts on my part. If any part of my Spyder did not work because it got wet. It needs new parts. They are all designed to be waterproof. Similar in design as the seadoo. All switch contacts are sealed within a rubber membrane. So if water got in. Time for a new switch. Spraying some WD40 into the switch will not cause any harm. The switch is sealed. Contact cleaner or electronics cleaner on the other hand. It will strip out any lubricant that may be present. Most of the sealed switches have a stainless steel ball bearing to press on the membrane to close the contacts. Because the lubricant is gone. It will stick to the membrane and tear it open. Then time for a new switch.
    Sep 2009
    La Valle, WI
    You do not need to put it in neutral to push on a trailer. The auto clutch is always released when off. If you can get the parking brake to release it will roll.
    2018 F3 Limited , Oxford Blue
    Invalid Emails
    Jul 2016
    dayton ohio
    Check the shut off switch you may have hit it while drying it off.
    Bossier LoUiSiAna
    Quote Originally Posted by Capt_Ron View Post
    Ron
    Spyders can handle rain power washing, blowing water up in sensitive areas not so much. You don't mention flood so thinking there's more to it than rain good fuses charged battery with good connections did you hear an audible "POP" & from where? was the fuse boxes dry when you were checking?
    You can load on trailer or tow truck in gear, will need to release P-brake manually if can't get power. Some info by Cptjam here: https://www.spyderlovers.com/forums/...n-Squared-Away
    Oct 2014
    Fort Mill, SC
    I agree with checking the fuses. I don't know about a F3, but my RTS has fuses in the frunk and under the seat. Check them all.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Jul 2016
    Huntsville Ontario
    Never new the RT had fuses under the seat. Where are they exactly?
    2016 RT Limited SE6
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by BrianO View Post
    Lift the seat. Look directly to the front of the brake reservoir. You will see a 6" X 1" black box. The cover is hinged. That's how it is on my 2011 RTS, not sure about others.
    1998 Honda Valkyrie
    US Navy Veteran
    Jul 2011
    You do not have fuses under the seat. On your 2016RT.
    May 2017
    Mesa, Arid-Zone-A
    The OP said something went "pop" when he tried to start it. That has me thinking the problem could be a main fuse? or something like that. I am not familiar enough with the electrical system to suggest where to look. But it looks to me like the rain caused something major to ground out.....? Jim
    Semper Fi
    Mar 2017
    third rock from the sun
    Is it possibly a relay rather than a fuse?
    Dec 2017
    Emmetsburg, Iowa
    Capt. Ron my F3 has been in the shop for a month for the classic I dunno, I see someone wants to trade their motorcycle?
    2018 F3 , Full size brake pedal Black
    Mar 2015
    West Palm Beach, FL
    Thank you all for the replies. Sorry I haven't posted. Work is busy.
    There was an audible "POP" when I turned the key originally.
    I blew out the ignition switch with canned air. I checked all the fuses None are blown. The battery should be fine and the connections are solid.
    Still nothing happens when I turn the key.
    How do I check the relays? Or do I just replace them all. Is there a ""master fuse" that is not in the fuseboxes?
    I'm thinking that it may be the ignition switch itself. The "Pop" did not sound like it came from the front.
    I know if I have it towed into the dealer and have them repair the trike, it will be very expensive. How hard would it be for me to replace the ignition switch? Seems like it should be easy. Should I just try that and the relays, then submit to the Dealer's abuse? (relays would be first)
    Thank you all for your thoughts and suggestions.
    Ron
    Mar 2015
    Tacoma WA.
    Also Caig De-Oxit. Cleans and dries with no residue, and is safe on plastics.
    2017 F3-S Daytona , Yellow and black
    Mar 2015
    Tacoma WA.
    Quote Originally Posted by canamjhb View Post
    I'd be looking at a fried ignition switch. Not good, as when it popped it might have also taken out the anti-theft circuit or gone even to the ECU.
    Mar 2015
    Tacoma WA.
    Just curious, how would one release the brake manually in case there's no power?
    Nov 2012
    North Las Vegas, NV
    Ron
    It will roll in gear. Just release the brake.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
