Results 1 to 25 of 25
    Jul 2011
    Mitchell, Ontario, Canada
    Default Garmin map update.
    For those of you with a Garmin GPS with lifetime maps. A new map 2020.20 has been released.
    PS this is a North American map.
    Thanks, Billy, I just got the word from Garmin but not the version number.
    Dec 2012
    Murphy, NC
    Thanks Billy. I just downloaded the newest version about an hour ago.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Active Member Sarge's Avatar
    Yanceyville,NC
    Guess I'll have to set it up to download overnight. My DSL SUX! At 1.2 Mb/s it'l take about 3-4 hours. Thanks for the tip!
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Bryant, Arkansas
    Thanks Man
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Speaking of Garmin, my ZUMO 660 battery is dying (won't hold a charge) and I can't find a replacement locally. I'm being told by some "good luck, it's a Garmin only item and it's probably not supported anymore." Curious...….Has anyone had to replace their battery for this item?
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Jul 2011
    Quote Originally Posted by teninospyder View Post
    Amazon
    Mar 2013
    Ray,
    I may still have the two batteries from our 660 that died from a different cause. If I do you can have them. I should be home from our trip by Sunday. I will let you know.
    Les
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jan 2017
    Vancouver, B.C.
    Just loaded up my 3 Garmin's with the 2020.20
    Zumo 595 Done
    Nuvi 3597 Done
    Nuvi 3790 Done
    Thanks Billy
    2016 F3 Spyder Limited SE6
    2005 Honda ST1300 ABS
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    thank you for always keeping us updated !!
    [joyce & irvin toms]
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    I also have a ZUMO 660, and it is new to me. How do you find this battery and where it is located? Thanks.
    Can Am 2013 RTL SE5
    Jul 2011
    Quote Originally Posted by wingit3611 View Post
    There is a slider on the bottom of the Zumo 660. Slide it and the battery cover door will release. Take off the door and there is the battery. Also there is the usb plug you use to connect to your computer to update the firmware and maps.
    PS Here is a link to the owners manual. https://www.gpscity.com/pdfs/manuals...-EN-MANUAL.pdf
    Yanceyville,NC
    https://www.amazon.com/Replacement-0...6CWMV3M1QP0FZR
    Battery for Garmin Nuvi 500, Nuvi 510, Nuvi 550, Zumo 220, Zumo 600, Zumo 650, Zumo 660, Zumo 660LM, Zumo 665, Zumo 665LM, Aera 500, Aera 510, Aera 550, Aera 560 GPS Units
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Anyone else running out of memory space? On my last updates(haven't done this one).....on two 665's & one 660, I had to limit the geographical area updated, because of lack of memory space.
    Jul 2011
    Quote Originally Posted by Jeriatric View Post
    Install a micro SD card. Not sure the maximum size it will take. The manual should have that info.
    Mar 2013
    Quote Originally Posted by PW2013STL View Post
    Ray,
    Les
    Sorry Ray!
    Looks like I tossed them.
    Les
    Apr 2012
    https://www.newegg.com/p/0N1-0047-00009
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Here's a fix for the 590 batteries which may work for 660 ones if they have a similar connector:
    http://outsider-adventure.blogspot.c...ttery-fix.html
    Fixed my 590 battery this way.
    Jul 2019
    Stoughton, Wisconsin
    I have a garmin lNUVI40 with lifetime maps. I just purchased a 2013 RT with a ZUMO 660. I updated the firm ware, but the map update costs $49. Does anyone know if there is a way to update the ZUMO with the NUVI update?
    Jul 2011
    Quote Originally Posted by JimmyD View Post
    So it appears that your ZUMO 660 does not have lifetime maps. So you either buy the lifetime map option for it or live with the way it is.
    Sep 2014
    tenino, wa
    Appreciate it very much.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Greenville Tx
    There is a fix for that. It is not the battery, it is the contacts . Here is a link that explains how to fix it. http://www.totally4bikers.com/blog/b...a-few-minutes/
    2017 F3 Limited
    Jul 2011
    Quote Originally Posted by AY4B View Post
    You are confusing a Zumo 590 with a Zumo 660. Different battery with method of connection.
    Sep 2014
    tenino, wa
    Appreciate the thought anyway
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Danbury Connecticut
    Thanks for the heads up.
    I used to dread these map updates. I had Frontier Communication as my internet provider.
    It could take as much as 4 hours to update the maps.
    I have two GPS. One for my Van and another for my Spyder.
    That's 8 hours to update maps. I'd start running the update before I went to sleep and let it run all night
    I changed to Xfinity about two weeks ago.
    I'm doing the update now. About 30 minutes for each GPS.
    WOW, what a difference.
    IBA #47122
    2020 RT Limited Asphalt Grey
