Results 1 to 17 of 17
Thread: Cleaning
    Jul 2019
    Illinois
    Default Cleaning
    What do you all use to clean the Tupperware on your bikes I want to keep it new looking even though it is a 2008 gs se5
    Northern Kalifornia
    Soap and water, then dry it off.
    For a serious cleaning: I used a good car wash soap...
    For the quick touch-ups: Lamont's Black Diamond Detailer was the key...
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Quote Originally Posted by Vincere View Post
    Car wash soap. It's cheap. Then Pledge or most any quality spray bottle detailer/wax system like liquid ice will help keep it looking spiffy.
    Feb 2019
    Portland, Oregon
    S-100 polish for those spider-webby scratchs. Meguiar's yellow 26 wax. Griot's Garage Best of Show detailer. All three are the best I have found, so far. Shine is deep and slick.
    Nov 2018
    Denver, Colorado
    Maxima SC1 clear coat....This stuff is amazing! It will keep your black ..black and turns your color on your bike new again. This also keeps it cleaner from wash to wash. Got it on EBAY, cheaper than Amazon. Check it out on you tube.
    May 2019
    New Mexico
    Car wash soap to clean. S100 detailer and wax for everyday shine. At the end of summer I'll go over it with a clay bar and then a good coat of "Liquid Glass" nano wax.
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Soap and water then polish with lemon pledge the bugs comes right off, the bike shines and smells good too. Seriously Lemon Pledge works great.
    Lemon Pledge is cheap simply spray on then wipe and buff just as you would any other wax.
    To be continued....
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I've always used dollar store "pledge" on the windshield. Makes the bugs come off easy.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Jan 2019
    Blue Mounds Wi
    For me I use the two dryer sheets in a spray bottle with distilled water for bug removal. Then use all wheel(paint safe) and tire cleaner on rims and tires. Then car wash soap it all off. I use my electric leaf blower to get all the water out of the mirrors and other crevasses then dry. I have been using the plexus polish on the windshield because I had a can. It is pretty expensive so I will find an alternative. Then I use LUCAS speed wax on the painted Tupperware. Finally I use a wet tire product on the rubber. Leather conditioner wipes on the seat. Armorall matt on the black painted stuff.Pretty spa-ish but I love my spyder.
    Oct 2016
    Faribault, MN
    +1 Lamont's Black Diamond Detailer was the key...
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jul 2019
    Illinois
    Thank you I appreciate all the responses
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    I start always using a good car wash soap lubricates so no scratches and now I finish with Mothers CMX. Keeps her very clean and the water just rolls off.
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    I have a few spots of what looks like bug splatter that will not come off .I is as if it is in the clear coat .I have tried scratch doctor ,but it will not come off .Short of taken it to a body shop what do you use ?
    2018 RTL , dark blue
    Bug splatter will dissolve if you spray with hydrogen peroxide. I have washed the whole bike with it for a quick wash.
    Sep 2017
    Ashburn, VA
    Regardless of what wash you use and how you wash it, the trick is to dry it with an electric leaf blower (be careful...electric and water don't mix very well). It works wonders!
    SpyderSkeets
    Ashburn, VA
    2017 F3-T SE6
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    I really like CSI Q7 Detailer. I spray a little bit on, rub it in with a microfiber towel and then buff with a different microfiber towel. Goes on very quickly and easily yet produces a uniform and shiny surface. https://youtu.be/s1xSbvl_I1k.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
